Loading...
Pages: [1]   Go Down
Author Topic: ds18b20  (Read 154 times)
Offline Offline
Full Member
View Profile
WWW
Otra cosa mas,
Estoy probando el termometro ds18b20, y la cargar el siguiente código muestra el código -1000, es decir en un de los if de control a ver si me podeis indicar porque. O bien si teneis otro código para dicho termometro
#include <OneWire.h>
int DS18S20_Pin = 2; //DS18S20 Signal pin on digital 2
//Temperature chip i/o
OneWire ds(DS18S20_Pin);  // on digital pin 2
void setup(void) {
void loop(void) {
  float temperature = getTemp();
  Serial.println(temperature);
  delay(100); //just here to slow down the output so it is easier to read
float getTemp(){
  //returns the temperature from one DS18S20 in DEG Celsius
  byte data[12];
  byte addr[8];
  if ( !ds.search(addr)) {
      //no more sensors on chain, reset search
      ds.reset_search();
      return -1000;
  if ( OneWire::crc8( addr, 7) != addr[7]) {
      Serial.println("CRC is not valid!");
      return -1000;
  if ( addr[0] != 0x10 && addr[0] != 0x28) {
      Serial.print("Device is not recognized");
      return -1000;
  ds.reset();
  ds.select(addr);
  ds.write(0x44,1); // start conversion, with parasite power on at the end
  byte present = ds.reset();
  ds.select(addr);
  ds.write(0xBE); // Read Scratchpad
  for (int i = 0; i < 9; i++) { // we need 9 bytes
    data = ds.read();
  ds.reset_search();
  byte MSB = data[1];
  byte LSB = data[0];
  float tempRead = ((MSB << smiley-cool | LSB); //using two's compliment
  float TemperatureSum = tempRead / 16;
  return TemperatureSum;
Logged
Pages: [1]   Go Up
Print
Jump to:
