Pages: 1 2 3 [4]   Go Down
Author Topic: i am sorry!!!  (Read 1691 times)
UK
a bunch of people give me different bits and incomplete bits of information
That's where experience and willingness to learn and filter come in helpful.
What "other forum" ?
Rhode Island - USA
ps,
never asked for anyone to "draw me up a "schematic" - but somebody could have pointed me to one that suits my project.. i haven't come across one as of yet - but hey, i'm not the one teaching am i?
SE USA
@ssh0le
have you learned about a single led and resistor yet? then take that and span it over 300 led's, your going to encounter more problems along the way but we can address them as they come up. You got to take some initiative and figure some of this out instead of carrying on this idea that someone is going to personally devote their life to hold you by the hand in every single moment of your project.
California
ps,
So your frustration has to do with us not having a schematic at-the-ready to post for the exact specifications you are looking for?
UK
There you go again with the "teaching" thing.
What do you understand by the term "forum"?
Boston area, metrowest
Online Online
Read the datasheet for WS2803, develop your code from there.
maybe this teaches you something....GOOGLE !
https://www.google.com/search?q=rgb+led+schematic+arduino
that will be 5 dollars for the teaching leasson
* Si preguntas, pon el código de tu programa, hace mucho mas fácil ayudarte. Y me ahorro un mensaje pidiendo que lo hagas.
* Si consigues solucionar tu problema, dedica unos minutos a explicar en tu post como lo conseguiste para beneficio de todos.
* Cambia el 'Subject' de tu hilo y añade 'SOLUCIONADO' cuando hayas llegado a una solución al problema que planteaste.
* Utiliza un 'Subject' para tu hilo que explique de que va el hilo.
Si estas empezando:
* Comienza a usar Arduino
* Guías de iniciación a Arduino
* Ejemplos
* Referencia del Lenguaje
* Conceptos básicos
Guia de usuario de arduino
Tutoriales en Ingles
Si necesitas que alguien te escriba el código: http://www.freelancer.com/  o esta  http://www.guru.com/
Rhode Island - USA
100 RGB LEDs, you can control 6 each with WS2803 with full color fade control, just need 17 chips if you don't want to muliplex them.
Available on e-bay (only place I've seen them in fact)
http://www.ebay.com/sch/i.html?_trksid=p5197.m570.l1313&_nkw=ws2803&_sacat=0&_from=R40
and only from 1 place in Niagara Falls, NY
Have read that WS2801 library is similar to what's needed for WS2803.
Or just wire up a chain of 100 of WS2801, and send out the 100 pieces of information needed for each RGB LEDs color based on your user input.
this was helpful, thank you.. but i was actually thinking of multiplexing them.. not sure if that's the way to go tho.
Online Online
I'd suggest starting with 1, get the resistance values figured out for your particular RGB LED, get some basic code to work to understand the datasequence needed, then build up from there.
To multiplex, you will need banks of PNP transistors or P-channel  MOSFETs to control the voltage to the parallel'ed LEDs.
What kind of architeture were you thinking?  'x' banks of 'y' LEDs using 'z' WS2803s?
« Last Edit: December 26, 2012, 05:40:51 pm by CrossRoads » Logged
Rhode Island - USA
just pm'd you about that.. smiley
Me too!!!  I'm sorry, help!!!
Last summer, I bought an adjustable wrench. I want to build an engine, or a small transmission. But I don't have any clue about cars.
i'm told what i want to accomplish is not an easy thing.. how can it not be - they are just freaking bolts!!!
Online Online
What he needs is not difficult - just 13 MAX7219's and 400 2-color LEDs, or 2 LEDs wired together as a 2-color LED.
Each MAX7219 driving 32 LED pairs. Piece of cake. No PWM needed.
Seattle
Perhaps you should inquire on reddit.com/r/vxjunkies
The VX crowd might be able to offer some insight into this problem.
I have a late 90s VX2, still works great, never saw the need to upgrade.
--creatrope
Online Online
What is "VX" in this context?
Pages: 1 2 3 [4]   Go Up
