Topic: Arduino Networked Lamp Processing sketch error. (Read 12815 times) previous topic - next topic
PaulS
Quote
but now it can't load the HelveticaNeue-bold font...
Does the font that Processing uses REALLY matter? Have you placed the appropriate font file in the appropriate directory?
Forrest_Erickson2002
I was not able to figure out how to fix the font problem so I simply commented out the lines like this:
  //font = loadFont("HelveticaNeue-Bold-32.vlw");
  fill(255);
// textFont(font, 32);
Then the program ran but produced no results.
The URL from the book is not responding I think.
I changed the URL like this:
String feed = "http://blog.makezine.com/index.html";
I was then getting results .
Thanks for the help above with the java includes. I would never have overcome that problem.
Tyson: When you're scientifically literate, the world looks different to you.
thomm
Hi all, i am not very familiar English, sorry for my poor English.
I am now using processing 2.1 for this project and i've revised my code by including java with codes mentioned above:
import processing.serial.*;
import java.net.URL;
import java.net.URLConnection;
import java.io.BufferedReader;
import java.io.InputStreamReader;
import java.util.StringTokenizer;
yet, when I tried to run this program, Processing stopped and show error message  "The package "java.io,BufferReader" does not exist. You might be missing a library."
I'm a totally newbie ,I don't know if it is suitable to ask here (this is the only forum I know)
Is there any suggestion where I can download the libraries and how to install it?
PaulS
The error message does not match with the snippet of code you posted. (Buffered != Buffer).
thomm
thanks! this error is caused by my typo... :smiley-sad-blue:
tgreenhaw
You'll need to go to the "Tools/Create Font..." menu option. I didn't have Helvetica so I used Calibri. You'll also need to change the reference to the font in the code as well.
Example:
  font = loadFont("Calibri-48.vlw");
sunnybee
Hello Everybody,
Sorry I am totally new and confused by this.  May I ask where to get the 1.5.1 version of Processing and how to run this processing?  I am using 64 bit Windows 8.  your advice will be appreciated.
PaulS
Quote
Why do you think you need such an old version?
