Topic: ARDUINO DUE DAC0 NON FUNZIONA!! (Read 920 times) previous topic - next topic
Fraa93
Dec 26, 2012, 11:21 pm Last Edit: Dec 26, 2012, 11:25 pm by fraa93 Reason: 1
La porta DAC0 non funziona in seguito al tutorial : http://arduino.cc/en/Tutorial/SimpleAudioPlayer
come mai?, come posso risolvere?
The pin DAC0 does not work following the tutorial: http://arduino.cc/en/Tutorial/SimpleAudioPlayer
why?, how can I fix this?
jgmdavies
Ciao - Have you seen this thread?
   http://arduino.cc/forum/index.php/topic,129765.0.html
Jim
Fraa93
#2
Dec 27, 2012, 05:48 pm Last Edit: Dec 27, 2012, 05:51 pm by fraa93 Reason: 1
Si grazie, appena provo l'esempio ti farò sapere, anche se sono quasi convinto che la porta DAC0 si è bruciata a causa dell'esempio (http://arduino.cc/en/Tutorial/SimpleAudioPlayer) fatto male, dato che dice di collegare lo speaker al pin senza uso di resistori...  ;)
Sure you can, just try the example I'll let you know, although I am almost convinced that the door DAC0 has burned out because of the example (http://arduino.cc/en/Tutorial/SimpleAudioPlayer) was wrong, as it tells you to connect the speaker to pin without the use of resistors ... ;)
jknighton
I have the same issue, and I am similarly convinced that DAC0 is now non-functional because I followed the Simple Audio Player example.  I don't suppose there is any chance of redress?  A bit bummed to find that one of two DAC pins is now non-functional just from following directions.
