Topic: help with 74HC595 controlling induvial leds (Read 2197 times) previous topic - next topic
turtlesoup2
hi im tinkering around with a 74HC595 chip and i was trying to figure out how to controll induvial leds. all the guides about these chips are just about understanding how it works and not how to program it. I understand how it shifts in data, but I am unable to creat a correct code to turn induvial leds on.
with the code below i was able to turn on led #1 , but when i was unable to turn any single one on..
//Pin connected to ST_CP of 74HC595
int latchPin = 8;
//Pin connected to SH_CP of 74HC595
int clockPin = 12;
////Pin connected to DS of 74HC595
int dataPin = 11;
  //set pins to output so you can control the shift register
  pinMode(latchPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
  pinMode(dataPin, OUTPUT);
  // count from 0 to 255 and display the number
  // on the LEDs
  for (int i = 0;i < 2; i++) {
    // take the latchPin low so
    // the LEDs don't change while you're sending in bits:
    digitalWrite(latchPin, LOW);
    // shift out the bits:
    shiftOut(dataPin, clockPin,00000001, i);
    //take the latch pin high so the LEDs will light up:
    digitalWrite(latchPin, HIGH);
    // pause before next value:
    delay(1);
Osgeld
toss a B in front of 00000001 to tell the compiler that is a Binary representation of the number
shiftOut(dataPin, clockPin,B00000001, i);
turtlesoup2
So if I wanted to turn just led #8 on I would change B00000001 to B10000000? That's it?
Osgeld
#3
Dec 27, 2012, 06:24 am Last Edit: Dec 27, 2012, 06:28 am by Osgeld Reason: 1
if its wired correctly ... ayep
actually you have the function wrong
shiftOut(dataPin, clockPin, bitOrder, value)
so
shiftOut(dataPin,ClockPin, MSBFIRST (or LSBFIRST), B00000001);
http://arduino.cc/en/Reference/ShiftOut
turtlesoup2
ok i think i get it now. using this code i was able to turn one leds and make them flash at different intervals.
int latchPin = 8;
int clockPin = 12;
int dataPin = 11;
  // on the LEDs
  for (int i = 0;i < 256; i++) {
    shiftOut(dataPin,clockPin, MSBFIRST, B01000000);
    shiftOut(dataPin,clockPin,MSBFIRST, B00000001);
    delay(200);
    digitalWrite(latchPin,LOW);
    shiftOut(dataPin,clockPin,MSBFIRST,B00000100);
UKHeliBob
PaulS
