Topic: ATMEGA644 Serial1 can't work (Read 5582 times) previous topic - next topic
catchup
Dec 27, 2012, 06:05 am Last Edit: Dec 27, 2012, 07:18 am by catchup Reason: 1
Hi All,
I am using atmega644 with  sanguino 1.01 , we met a problem when testing serial1. atmega644  would halt  after calling  "Serial1.println" several times  and  there also did't have anything output on USART1.  anyone can help us?
// the setup routine runs once when you press reset:
 Serial.println("Starting...");
 Serial1.begin(9600);
 Serial1.println("Serial1 Starting...");
  Serial.println("loop");
  Serial1.println("loop1");
Osgeld
what is serial 1 connected to?
catchup
#2
Dec 27, 2012, 06:07 am Last Edit: Dec 27, 2012, 07:19 am by catchup Reason: 1
Hi All,
nickgammon
Please do not cross-post. This wastes time and resources as people attempt to answer your question on multiple threads.
Threads merged.
Read this before posting a programming question
Please edit your post, select the code, and put it between [code] ... [/code] tags.
You can do that by hitting the # button above the posting area.
- Moderator
catchup
we got same result no matter serial1  pin (RXD1,TXD1) were empty  or connected to RS232 driver.
nickgammon
Did we? But you decided not to follow my advice about the code tags did you?
PaulS
Well, now, there's a surprise.
So, it must be a programming issue? Not hardly.
catchup
it should not be programming issue, The same codes run well on ATMEGA2560.  There should be a bug with arduino  ATMEGA644 SDK
westfw
If you have a real atmega644, and not a 644a or 644p, then I think that in fact it only has one UART!
Tom Carpenter
Yup, only the larger AtMega1284 from that series has two UARTs.
~Tom~
retrolefty
No the 644p does have two serial ports, the 644 just one.
Lefty
Tom Carpenter
I was counting the 'p' ones as a seperate series, but yeah the 644p has two.
catchup, do you have the Atmega644p or the atmega644?
(note that the 'p' is not the same as 'pu', for example there are AtMega644P-PU and AtMega644-PU).
~Tom~
catchup
thanks for your help. I am using ATMEGA644 even the signature is the same as ATMEGA644A,  after changing to using ATMEGA644P, It worked.
westfw
Yes, I consider the fact that the 644 (one uart) and 644a (two uarts) have the same device signature to be a pretty big mistake on Atmel's part...   Grr.
dd4da
Take a look to the mapping if the ISR for the serial Port you wanna use. I have did some fixes in Arduino103 environment for m644,644p , 1284p to use the the serial port. The #defines of the
supportet ATMega variants are not complete in all purposes. Just extend them and add your MPU model to the right register definition.
Take a look to the compilers mapping file and compare the IRQ Vectors he mapped with the datasheet of the MPU you use.
Hi All,
