Pages: [1] 2   Go Down
Author Topic: HELP !! arduino solar panel battery and 2 motor servo  (Read 1899 times)
hi ..
I just finished with this project ..http://www.instructables.com/id/Self-Sufficient-Arduino-Board/?ALLSTEPS
but why when i loose the power of the computer and run my project, the servo motor does not move according to my previous projects?? http://www.instructables.com/id/Arduino-Solar-Tracker/
I combine these two projects into one project and run it ..
the question is
why the project is not going to use batteries??
How can i read the voltage of battery(battery indicator)?
I use ultra accuplus 9V battery or eveready 9V..
thanks in advance
Seattle, WA USA
Seattle, WA USA
You are trying to use 1 dinky little 9V battery to power two current-hungry servos? And, they don't work? No surprise, there.
With a voltmeter.
Thx for your usefull comment paulS, can i make a voltmeter just with an arduino?
So what i have to do to move servo without 9V battery?
Netherlands
yes, even a 6 channel voltmeter, looks like
//    FILE: Voltmeter.pde
//  AUTHOR: Rob Tillaart
//    DATE: 2012-12-27
// PUPROSE: 6 channel voltmeter
int pin[] = { A0,A1,A2,A3,A4,A5 };
  for (int i=0; i<6; i++)
    analogRead(pin[i]);
    float voltage = analogRead(pin[i])*5.0/1023;
    Serial.print(voltage, 3);
    Serial.print("\t");
  Serial.println();
  // delay(100);
Output can easily be copied into Excel or so.
« Last Edit: December 27, 2012, 10:27:18 am by robtillaart » Logged
Rob Tillaart
Seattle, WA USA
Seattle, WA USA
You need a real source of power. The servos can easily draw 1/2 and amp apiece.
Hai rob tilaart thank you very much..
But why the baudrate set so big? I usualy set for 9600, and i have use my analogpin for ldr and potentiometer, do you have another way?
paulS
What do you mean with real source of power?
Netherlands
setting the baudrate higher means less time spend on communicating and more time on measurements/math. 115200 is 12x faster than 9600
Communicating a string of 6 measurements, lets say 30 bytes including spaces and \n takes approx:
@115200:  3 msec
@9600: 30 msec
analogReads take approx 0.1 msec lets say including all math 1 usec so lets say 6 channels take 6 msec.
1 set of measurements
@115200:  9 msec  => 111/sec
@9600: 36 msec => 27 /sec
So in the end the higher speed serial allows me to take 4x as much samples.
Instead of more samples I can use the extra time to do additional math e.g. averaging and keep minimum/maximum per channel.
Although the IDE serial monitor does not support it, the Arduino can send data as fast as 500,000 Baud. The effect is that you can go up to ~150/second.
Rob Tillaart
Seattle, WA USA
Seattle, WA USA
Is your solar panel/battery setup able to supply 1A of power to the servos? If not, you need something that can - a real source of power.
Rob tilaart thank you very much..
On your 6 channel voltmeter, how you get the formula of float voltage? Explain me please..
And how do i put the battery on arduino with solar panel? Can i use digitalpin for my voltmeter?
paulS
I think my solar panel has 9V supply, how do you think?
Seattle, WA USA
Seattle, WA USA
how do you think?
The voltage is far less important than the amperage. I've yet to see a solar panel that could supply 1A of current. That is what you need to drive two servos.
Thanks paulS
can you help me with the schematic? How can i put the solar panel to charge the battery and measuring. battery on my arduino uno r3?
Seattle, WA USA
Seattle, WA USA
Beats me. That's a hardware issue. I'm a software type.
Ooh, i see paulS. I have another question.
When my servo sweeping based on ldr, i do serial println on my ldr in the same time, why the servo movement going to slow when i do this? But when i unmark the serial println the servo movement going back
to normal..
Anybody help me please with the schematics to charge and measuring battery on my
arduino..
Seattle, WA USA
Seattle, WA USA
to normal..
Move. Print several characters to the serial port. Move. Print several characters to the serial port.
or
Move. Move. Move. Move.
Which is going to result in more moves per unit of time? What does move moves per unit of time mean? Yep, faster.
iam sorry paulS i dont understand about your reply..
can you explain me with more details explanation about my problem??
Pages: [1] 2   Go Up
