Author Topic: Hobby Servo and Continuous Rotation Servo , is it the same?  (Read 176 times)
is it the same library for Hobby Servo (Normal) with Continuous Rotation Servo ? Thanks
Seattle, WA USA
Seattle, WA USA
Have you tried?
Yes, it is.
I don't think it is different. You can use servo.h for hobby as well as full rotation servos. Hobby servo often go from 0 to 180 degrees whereas the other one goes 360 degrees.
South Texas
Not quite - a hobby servo moves somewhere in the range of 180 degrees - depends on the internal stop in the geartrain.
A continuous rotation servo givesd you some control over speed. 90 degrees is stop and 0 degrees is full reverse and 180 degrees is full forward. You have no control over positin, just some control over speed with a few degrees around 90 as stop.
A hobby servo can be modified into a continuous rotation servo with a couple resistors and some destructive hacking...
Left Coast, CA (USA)
Measurement changes behavior
Yes, same servo library supports both types of 'servos'. However the two different types of servos (normal Vs continuous rotation) respond quite differently to the servo.write command. A normal one moves to a specific position and stops while the other acts like a reversible variable speed geared motor drive where you can control the thing to stop or move in either direction at a variable speed, but you cannot command it to stop at a specific position.
Lefty
Thanks all for the answers, appruciate it. i have tried to hack hobby servo into continuous but it's a waste and almost ruin my whole servo. better be carefull, or just buy a new one haha. smiley-confuse
