Loading...
Pages: [1]   Go Down
Author Topic: Red LED matrix with TLC5940  (Read 393 times)
Offline Offline
Newbie
View Profile
Hi all,
I'm just starting playing with a 8x8 red led matrix that I got, my first attempt was somehow successful, but was using all my arduino pins.
So I'm now trying to use a TLC5940 to control the matrix and keep some pins free on the arduino... But it doesn't work! smiley-sad
For the first attempt (without TLC5940), I've just followed the RowColumnScanning tutorial (http://arduino.cc/en/Tutorial/RowColumnScanning), got it working fast, I just add to revert column 4 and column 6 pins, to adapt to my matrix. (I don't have the datasheet of my matrix...), then setting first row to HIGH and first column to LOW was actually lighting my first LED.
Then, moving to TLC5940, I didn't found any simple project example to drive such a simple "one color matrix", but my idea was to use the 8 first outputs of the TLC5940 to set COLUMN values, and the 8 last outputs to set ROWS values in order to be able to control each LED individually. I thought that, using the TCL5940 library form here (http://code.google.com/p/tlc5940arduino/), the following code would do the same effect as when using digitalWrite() in the first attempt:
Code:
Tlc.set(0, 0); // channel 0 is COL1
Tlc.set(8, 4095); // channel 8 is ROW1
Tlc.update();
=> it doesn't work
BUt I I put +5V directly on ROW1, and do Tlc.set(0, 4095), I get the light on first LED...
So I think I've not understood how it should work with the TLC5940....
Is it correct to think that I can control ROWS and COLUMNS with the 16 outputs of the TLC5940?
Then is it supposed to work using the .set() function, as when I was using the digitalWrite with arduino's outputs?
Does anyone as an example of such project?
Thanks a lot!
Cheers,
Michael
Logged
Valencia, Spain
Offline Offline
Edison Member
View Profile
I think you might be confusing the TLC5940 with the MAX7219.
The TLC5940 can't output current on any of its pins.
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
TLC5940 sinks current on all outputs at individually commanded PWM levels.
The way a matrix works is that you drive the anodes, sink one column, drive the anodes, sink the next column, etc., and persistance of vision gives the illusion of all LEDs being driven together.
Can't really do that when you have 16 outputs all sinking current at their commanded PWM rates.
For a matrix, use a part like MAX7219, $1.25 from Taydaelectronics.com, inexpensize shipping as well.
Takes care of the multiplexing for you, so all you need to do is write to 1 of 8 registers to update a column of data as needed.
Brightness of the entire display is controllable also.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Offline Offline
Newbie
View Profile
Thanks for you answers! I'm quite disappointed though, I thought it would work with the TLC as I saw several LED projects using it, but seems not as easy as with the MAX7219, which I didn't find at my local store. smiley-sad
I'll check for ordering it, but with shipping to France, it might get quite expensive... anyway... smiley
So with you comments, I got something more or less working by plugging the ROWS to arduino's outputs, and the COLUMNS to the TLC, but it's a bit awkward to use...
Let's go for the MAX7219!
Thanks a lot,
Michael
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Shipping to the US is not expensive, let us know the charges to France. I usually buy other stuff too, plan ahead for future projects or just to have parts on hand to experiment with.
Logged
Valencia, Spain
Offline Offline
Edison Member
View Profile
It's not commonly used for matrices.
You can get them cheap on eBay...
Logged
Offline Offline
Newbie
View Profile
ok, I'll let you know for shipping price to France. smiley
One last question, the MAX7219 description on the website you gave me says "Common Cathode serially interfaced display driver".
(http://www.taydaelectronics.com/max7219-7-segment-dot-point-common-cathode-serially-interfaced-display-driver-pdip-24.html)
But I think the matrix is a common-anode one. (not sure though).
Will it work anyway?
Thanks,
Michael
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Sure, you just need to orient your display a little differently. For example, look at these two devices:
http://www.futurlec.com/LED/LEDMS88WH-CA.shtml
http://www.futurlec.com/LED/LEDMS88WH-CC.shtml
So if you take one, turn it 90 degrees, you can see that both can have anodes that can be driven as rows, and cathodes that can sink an entire column at once.
The Upper left diode may need different pins to turn it on, pins 9/16 for the left matrix and pins 8/9 for the right, but a little thinking and keeping the wiring straight will allow accurate control of the columns.
Logged
Offline Offline
Newbie
View Profile
ok, thanks again!! smiley
Logged
Pages: [1]   Go Up
Print
Jump to:
