Author Topic: Arduino WiFi library and Copperhead v.2 wifi shield  (Read 298 times)
Greetings,
can someone help me understand why this WiFi library (comes with Arduino environment 1.03) does not work with the copperhead shield ? the shield works well with the Ada's WiShield library.
cheers,
Marian
Seattle, WA USA
Seattle, WA USA
Because the library is written for a different chip from the one that the copperhead shield uses.
So, why aren't you using that library?
what?
Thankfully i've only borrowed this idiot shield from my brother and not splashed out and bought it, has anyone actually got it to work?
I've cut my scetch down to the basics to try and debug it
#include <WiServer.h>
char buffer[5];
// Wireless configuration parameters ----------------------------------------
unsigned char local_ip[] = {192,168,2,10}; // IP address of WiShield
unsigned char gateway_ip[] = {192,168,2,1}; // router or gateway IP address
unsigned char subnet_mask[] = {255,255,255,0}; // subnet mask for the local network
const prog_char ssid[] PROGMEM = {"Belkin"}; // max 32 bytes
  sprintf(buffer,"Local IP = %d,%d,%d,%d",local_ip[0],local_ip[1],local_ip[2],local_ip[3]);
  Serial.print(buffer);
  Serial.println();
  sprintf(buffer,"Gateway IP = %d,%d,%d,%d",gateway_ip[0],gateway_ip[1],gateway_ip[2],gateway_ip[3]);
  Serial.println();
and this is what i get from the serial monitor
Local IP = 192,168,2,10
Gateway IP = 192,168,5,1
now if the gateway is defined as this
how the hell does it get this
I hate open source
Seattle, WA USA
Seattle, WA USA
Would you care to explain how all that stuff is supposed to fit in 5 bytes? That's how big your array is.
I hate open source
Well, I hate dumb coding.
what?
OK, i guess you've answered my question
but i'll humour you,
gateway_ip[0]
gateway_ip[1]
gateway_ip[2]
gateway_ip[3]
is only 4 bytes
char buffer[5]; is all that is required
Seattle, WA USA
Seattle, WA USA
gateway_ip[0]
gateway_ip[1]
gateway_ip[2]
gateway_ip[3]
is only 4 bytes
Wrong. You are using sprintf() to put "Gateway IP = " plus 3 commas plus 3 byte-sized values AS STRINGS plus the trailing NULL in the buffer. "Gate" and the trailing NULL fit in your 5 element buffer. None of the rest of the stuff fits.
