Author Topic: MQ-135 Value Conversion  (Read 355 times)
i've a mq135 - http://www.futurlec.com/Datasheet/Sensor/MQ-135.pdf
please anyone correct me if i'm wrong:
what i've undestand from datasheet is that
ppm  = Rs/Ro
Rs = mq135 readed resistence
Ro = sensor resistance at 100ppm of NH3 in the clean air (according to datasheet 30Kto200K)
i wire the sensor according to datasheet (see attached image, downloaded is from http://www.staceyk.org)
set RL = pulldown resistor (in the example 39K, according to datasheet any between 10KΩ to 47 KΩ)
so Rs = 1024*RL/adc - RL
the point here is to setup Ro, which means calibrate the sensor.
any help?
thank you,
davide
This is basic information : http://playground.arduino.cc/Main/MQGasSensors
Netherlands
Online Online
MQ sensors were discussed previous year here - http://arduino.cc/forum/index.php/topic,55780.0.html -
Rob Tillaart
yes, i've read the information you link.
but the key point is to find a valid Ro, i do not have a calibrated sensor, so i ask you if someone can tell me a valid Ro values for this chip.
thanks
Sorry, but that is not possible. Every sensor could be different.
i've made a mistake before, i consider Rs/Ro = ppm, but from fig.2 of datasheet is not so.
it seems that it is a power function (see attached).
so i made some power regression based on the values, and i obtain a scaling factor and an exponent
given those values
a = scaling factor obtained by datasheet figure, for the gas you need
b = exponent obtained by datasheet figure, for the gas you need
ppm = a*(Rs/Ro)^b
now, to obtain a valid Ro value, we have to know the ppm of a gas, for C02, we know the CO2 value for atmosphere,
http://www.esrl.noaa.gov/gmd/ccgg/trends/#mlo
so i can obtain Ro value for the chip in open air.
can this be right?
Netherlands
Online Online
can this be right?
Assuming you're not in Bejing with the current smog levels the answer is yes.
Rob Tillaart
can this be right?
i hope here near milan is not so high smiley
even if i can know it with precision i will approximate it to 394
