Hi there,
In Arduino 022 I am trying to compile the code below with todbot's softi2c master library (
https://github.com/todbot/SoftI2CMaster). It is my intention to get data from a uBlox GPS receiver using softi2c with an atmega32u2 (Teensy 1.0 compatible) with DFU bootloader. Codes like blink.hex can be compiled and run easily on this atmega.
However I get the following errors (and some more) compiling the code below: "DigitalPinToPort was not declared in this scope and "PortInputRegister" was not declared in this scope.
What might be wrong here?
#include "SoftI2CMaster.h"
const byte sdaPin = 0;
const byte sclPin = 1;
SoftI2CMaster i2c = SoftI2CMaster( sdaPin,sclPin );
#define BUFFER_LENGTH 10//buffer size
int GPSAddress = 0x42;//GPS address
double Datatransfer(char *data_buf,char num)//transfer:char to float
{ //*data_buf:char need to be converted;num:scalar
double temp=0.0;
unsigned char i,j;
if(data_buf[0]=='-')//negative number
i=1;
//char to int and accumulation
while(data_buf[i]!='.')
temp=temp*10+(data_buf[i++]-0x30);
for(j=0;j<num;j++)
temp=temp*10+(data_buf[++i]-0x30);
//int to float
for(j=0;j<num;j++)
temp=temp/10;
//convert to negetive number
temp=0-temp;
else//positive number
i=0;
for(j=0;j<num;j++)
for(j=0;j<num;j++)
temp=temp/10 ;
return temp;
void rec_init()//receive initialization
i2c.beginTransmission(GPSAddress);
i2c.send(0xff);//load address of the bytes
i2c.endTransmission();
i2c.requestFrom(GPSAddress);//require 10 byte from GPA
char ID()//info ID
char i = 0;
char value[7]={
'$','G','P','G','G','A',',' };//the info ID
char buff[7]={
'0','0','0','0','0','0','0' };
while(1)
rec_init();//receive initialize
// while(i2c.available())
buff[i] = i2c.receive();//get I2C data
if(buff[i]==value[i])//compare
i++;
if(i==7)
i2c.endTransmission();//end of transmission
return 1;//if end return 1
i=0;
void UTC()//get time info
char i = 0,flag=0;
char value[7]={
char buff[7]={
char time[9]={
'0','0','0','0','0','0','0','0','0' };//time buffer
double t=0.0;
while(1)
rec_init();
if(!flag)
i++;
if(i==7)
i=0;
flag=1;
i=0;
time[i] = i2c.receive();
i++;
if(i==9)
t=Datatransfer(time,2);//convert to float
t=t+80000.00;//change to BeiJing time
Serial.println(t);//print time
return;
void rec_data(char *buff,char num1,char num2)//receive data
{ //*buff:receive buffer;num1:num of comma;num2:size of buff。
char i=0,count=0;
if(ID())
while(1)
rec_init();
if(count!=num1)
if(buff[i]==',')
count++;
i++;
if(i==num2)
return;
void latitude()//get latitude info
char lat[10]={
'0','0','0','0','0','0','0','0','0','0' };//latitude buffer
rec_data(lat,1 ,10);//get latitude data
Serial.println(Datatransfer(lat,5),5);//convert to float
void lat_dir()//get latitude direction info
char dir[1]={'0'};//latitude direction buffer
rec_data(dir,2,1);//get direction data
Serial.println(dir[0],BYTE);//print the data
void longitude()//get longtitude info
char lon[11]={
'0','0','0','0','0','0','0','0','0','0','0' };//longtitude buffer
rec_data(lon,3,11);//get longitude data
Serial.println(Datatransfer(lon,5),5);//convert data to float
void lon_dir()//get longitude direction info
char dir[1]={'0'};
rec_data(dir,4,1);
void altitude()//get altitude info
char i=0,count=0;
char alt[8]={
if(ID())
while(1)
rec_init();
alt[i] = i2c.receive();
if(count!=8)
if(alt[i]==',')
count++;
if(alt[i]==',')
Serial.println(Datatransfer(alt,1),1);
return;
i++;
// i2c.begin();//I2C initialize
Serial.begin(9600);//set baudrate
Serial.println("GOF GPS Shield v1.0");
Serial.println("$GPGGA statement information: ");
while(1)
Serial.print("UTC:");
UTC();
Serial.print("Lat:");
latitude();
Serial.print("Dir:");
lat_dir();
Serial.print("Lon:");
longitude();
lon_dir();
Serial.print("Alt:");
altitude();
Serial.println(' ');
