Author Topic: softi2c master library error  (Read 297 times)
Hi there,
In Arduino 022 I am trying to compile the code below with todbot's softi2c master library (https://github.com/todbot/SoftI2CMaster). It is my intention to get data from a uBlox GPS receiver using softi2c with an atmega32u2 (Teensy 1.0 compatible) with DFU bootloader. Codes like blink.hex can be compiled and run easily on this atmega.
However I get the following errors (and some more) compiling the code below: "DigitalPinToPort was not declared in this scope and "PortInputRegister" was not declared in this scope.
What might be wrong here?
#include "SoftI2CMaster.h"
const byte sdaPin = 0;
const byte sclPin = 1;
SoftI2CMaster i2c = SoftI2CMaster( sdaPin,sclPin );
#define BUFFER_LENGTH 10//buffer size
int GPSAddress = 0x42;//GPS address
double Datatransfer(char *data_buf,char num)//transfer:char to float
{                                           //*data_buf:char need to be converted;num:scalar
  double temp=0.0;
  unsigned char i,j;
  if(data_buf[0]=='-')//negative number
    i=1;
    //char to int and accumulation
    while(data_buf[i]!='.')
      temp=temp*10+(data_buf[i++]-0x30);
    for(j=0;j<num;j++)
      temp=temp*10+(data_buf[++i]-0x30);
    //int to float
    for(j=0;j<num;j++)
      temp=temp/10;
    //convert to negetive number
    temp=0-temp;
  else//positive number
    i=0;
    for(j=0;j<num;j++)
    for(j=0;j<num;j++)
      temp=temp/10 ;
  return temp;
void rec_init()//receive initialization
  i2c.beginTransmission(GPSAddress);
  i2c.send(0xff);//load address of the bytes
  i2c.endTransmission();
  i2c.requestFrom(GPSAddress);//require 10 byte from GPA
char ID()//info ID
  char i = 0;
  char value[7]={
    '$','G','P','G','G','A',','      };//the info ID
  char buff[7]={
    '0','0','0','0','0','0','0'      };
  while(1)
    rec_init();//receive initialize
   // while(i2c.available())
      buff[i] = i2c.receive();//get I2C data
      if(buff[i]==value[i])//compare
        i++;
        if(i==7)
          i2c.endTransmission();//end of transmission
          return 1;//if end return 1
        i=0;
void UTC()//get time info
  char i = 0,flag=0;
  char value[7]={
  char buff[7]={
  char time[9]={
    '0','0','0','0','0','0','0','0','0'    };//time buffer
  double t=0.0;
  while(1)
    rec_init();
      if(!flag)
          i++;
          if(i==7)
            i=0;
            flag=1;
          i=0;
        time[i] = i2c.receive();
        i++;
        if(i==9)
          t=Datatransfer(time,2);//convert to float
          t=t+80000.00;//change to BeiJing time
          Serial.println(t);//print time
          return;
void rec_data(char *buff,char num1,char num2)//receive data
{                                            //*buff:receive buffer;num1:num of comma;num2:size of buff。
  char i=0,count=0;
  if(ID())
    while(1)
      rec_init();
        if(count!=num1)
          if(buff[i]==',')
            count++;
          i++;
          if(i==num2)
            return;
void latitude()//get latitude info
  char lat[10]={
    '0','0','0','0','0','0','0','0','0','0' };//latitude buffer
  rec_data(lat,1 ,10);//get latitude data
  Serial.println(Datatransfer(lat,5),5);//convert to float
void lat_dir()//get latitude direction info
  char dir[1]={'0'};//latitude direction buffer
  rec_data(dir,2,1);//get direction data
  Serial.println(dir[0],BYTE);//print the data
void  longitude()//get longtitude info
  char lon[11]={
    '0','0','0','0','0','0','0','0','0','0','0' };//longtitude buffer
  rec_data(lon,3,11);//get longitude data
  Serial.println(Datatransfer(lon,5),5);//convert data to float
void lon_dir()//get longitude direction info
  char dir[1]={'0'};
  rec_data(dir,4,1);
void altitude()//get altitude info
  char i=0,count=0;
  char alt[8]={
  if(ID())
    while(1)
      rec_init();
        alt[i] = i2c.receive();
        if(count!=8)
          if(alt[i]==',')
            count++;
          if(alt[i]==',')
            Serial.println(Datatransfer(alt,1),1);
            return;
            i++;
 // i2c.begin();//I2C initialize
  Serial.begin(9600);//set baudrate
  Serial.println("GOF GPS Shield v1.0");
  Serial.println("$GPGGA statement information: ");
  while(1)
    Serial.print("UTC:");
    UTC();
    Serial.print("Lat:");
    latitude();
    Serial.print("Dir:");
    lat_dir();
    Serial.print("Lon:");
    longitude();
    lon_dir();
    Serial.print("Alt:");
    altitude();
    Serial.println(' ');
Seattle, WA USA
Seattle, WA USA
That library may not be compatible with 0023 or earlier.
Or, upgrade to 1.0.0+. It compiles fine using 1.0.1.
Thanks for the answer.
It compiles now for me too with Arduino 1.03. I have made a mistake by naming the folder in which Arduino resides Arduino-103. Because of this, the code could not find Arduino.h, but after changing the folder's name from Arduino-103 into plain: Arduino, it worked  smiley
Thanks,
3dotter
Seattle, WA USA
Seattle, WA USA
That's strange, because mine is called Arduino-1.0.3, and it has no problem finding include files.
Plain Arduino is where I store my sketches.
