I've got this OLED from eBay:
http://www.ebay.com/itm/New-Version-Arduino-IIC-I2C-0-96-128X64-TWO-Color-OLED-Display-Module-AVR-PIC-/160889283903?ssPageName=ADME:L:OU:US:3160It have 8 pins:
PEN
VCC
3V3
GND
MIT
RST
SDA
SCL
It should work with this code:
// Wire Master Writer
// by Nicholas Zambetti <http://www.zambetti.com>
// Demonstrates use of the Wire library
// Writes data to an I2C/TWI slave device
// Refer to the "Wire Slave Receiver" example for use with this
// Created 29 March 2006
// This example code is in the public domain.
#include <Wire.h>
#define OLED_ADDRESS 0x51
#define WRITE_CMD 0x01
#define WRITE_DAT 0x02
#define RESET 0x03
#define DISP_8X16STR 0x10
#define DISP_AREA 0x11
#define FILL_AREA 0x12
#define SET_SCROHOR 0x13
#define SET_SCROVER 0x14
#define SET_SCROVERHOR 0x15
#define SET_ADDRESS 0x21
#define PAGE0 0x00
#define PAGE1 0x01
#define PAGE2 0x02
#define PAGE3 0x03
#define PAGE4 0x04
#define PAGE5 0x05
#define PAGE6 0x06
#define PAGE7 0x07
#define SCROLL_UP 0x01
#define SCROLL_DOWN 0x00
#define SCROLL_RIGHT 0x26
#define SCROLL_LEFT 0x27
#define SCROLL_VR 0x29
#define SCROLL_VL 0x2A
#define FRAMS_2 0x07
#define FRAMS_3 0x04
#define FRAMS_4 0x05
#define FRAMS_5 0x00
#define FRAMS_25 0x06
#define FRAMS_64 0x01
#define FRAMS_128 0x02
#define FRAMS_256 0x03
void Display8x16Str(uint8_t page, uint8_t column, const char *str)
Wire.beginTransmission(OLED_ADDRESS);
Wire.write(DISP_8X16STR);
Wire.write(page);
Wire.write(column);
while(*str != '\0')
Wire.write(*str++);
Wire.endTransmission();
void FillArea(uint8_t spage, uint8_t epage,uint8_t scolumn, uint8_t ecolumn,uint8_t filldata)
Wire.write(FILL_AREA);
Wire.write(spage);
Wire.write(epage);
Wire.write(scolumn);
Wire.write(ecolumn);
Wire.write(filldata);
void ScrollingHorizontal(uint8_t lr, uint8_t spage, uint8_t epage,uint8_t frames)
Wire.write(SET_SCROHOR);
Wire.write(lr);
Wire.write(spage);
Wire.write(epage);
Wire.write(frames);
void ScrollingVertical(uint8_t scrollupdown, uint8_t rowsfixed, uint8_t rowsscroll, uint8_t scrollstep, uint8_t stepdelay)
Wire.write(SET_SCROVER);
Wire.write(scrollupdown);
Wire.write(rowsfixed);
Wire.write(rowsscroll);
Wire.write(scrollstep);
Wire.write(stepdelay);
void ScrollingVertivalHorizontal(uint8_t fixedarea, uint8_t scrollarea, uint8_t vlr, uint8_t spage, uint8_t epage, uint8_t frames, uint8_t offset)
Wire.write(SET_SCROVERHOR);
Wire.write(fixedarea);
Wire.write(scrollarea);
Wire.write(vlr);
Wire.write(spage);
Wire.write(epage);
Wire.write(frames);
Wire.write(offset);
void DeactivateScroll()
Wire.write(WRITE_CMD);
Wire.write(0x2E);
void WriteCommand(const char *cmd)
while(*cmd != '\0')
Wire.write(*cmd++);
void WriteData()
unsigned int i;
Wire.write(WRITE_DAT);
for (i=0; i<20; i++)
// Wire.send(0xF0);
// Wire.send(0x0F);
for (i=0; i<32; i++)
Wire.write(0xFF);
void SetAddress(uint8_t page, uint8_t column)
Wire.write(SET_ADDRESS);
Wire.write(page);
Wire.write(column);
void Reset()
Wire.write(RESET);
Wire.begin();
pinMode(13, OUTPUT);
pinMode(12, INPUT);
Reset();
int i;
digitalWrite(13,HIGH);
for(i=0; i<8; i++)
SetAddress(i,0);
WriteData();
WriteData();
WriteData();
WriteData();
digitalWrite(13,LOW);
FillArea(0,7,0,128,0);
Display8x16Str(0,0, "Hello World!");
Display8x16Str(2,0, "Hello OLED!");
Display8x16Str(4,0, "Wellcom to use");
Display8x16Str(6,0, "Gem.Arduino");
ScrollingVertical(SCROLL_UP,0,32,1,250);
delay(3000);
ScrollingHorizontal(0x27, 4, 5, 0x07);
delay(2000);
DeactivateScroll();
ScrollingHorizontal(0x26, 6, 7, 0x07);
delay(2000);
DeactivateScroll();
FillArea(0,7,0,127,0);
Reset();
delay(2000);
Have anybody worked with this device? It seem to not work with this.
Connecting VCC to 5V and GND to GND, nothing shows up or blink...
I would really appreciate any thoughts...
