Topic: Logitech Wireless Keyboard/Reciver (Read 2235 times) previous topic - next topic
wespan
Dec 27, 2012, 11:50 pm Last Edit: Dec 28, 2012, 10:03 am by Coding Badly Reason: 1
I´m new to this forum and I would appreciate some input on my problem,
Im trying to use a C-BG17-DUAL logitech reciver with my arduino, but I have runned into some problems. I use the ps/2 cable
and have connected the clock signal and data cables to the digital inputs 3 and 4 and the power and ground into 5v and GND. The
reciver starts up nice. But when I try to pair the reciver with the keyboard it dissconnects after just a second.
I have used this sketch, I´m afraidthat there is some special setup och handshake nessesary between the arduino and the wireless-reciver. Any ideas or tips on how to move on?
Thanks a lot in advance
Mattias W.
* an arduino sketch to interface with a ps/2 keyboard.
* Also uses serial protocol to talk back to the host
* and report what it finds. Used the ps2 library.
#include <ps2.h>
* Pin 5 is the ps2 data pin, pin 6 is the clock pin
* Feel free to use whatever pins are convenient.
PS2 kbd(3, 4);
void kbd_init()
 char ack;
 kbd.write(0xff);  // send reset code
 ack = kbd.read();  // byte, kbd does self test
 ack = kbd.read();  // another ack when self test is done
 kbd_init();
* get a keycode from the kbd and report it back to the
* host via the serial line.
 unsigned char code;
 for (;;) { /* ever */
   /* read a keycode */
   code = kbd.read();
   /* send the data back up */
   Serial.println(code, HEX);
  // delay(20);  /* twiddle */
Moderator edit: [code] [/code] tags added.
robtillaart
please use the # button above the smileys when posting code . You will get appropriate tags that makes reading much easier .
How do you power the system? the Logitech may draw more current than you can give...
Rob Tillaart
wespan
Hi!
Thanks for letting me know about the #.
I will try to supply the current externaly, but the set up right now is:
The reciver is powered directly through the arduino 5v ., the arduino is connected through the usb cable. The remote keyboard is powered through batteries, but they are new, and I can inisiate the pairing from the keyboard (there are some led´s on the reciver blinking and is lit for a short while but then 2 of the leds,the ones indicating a connection is established, are turned off again.)
To me it seems to be a problem when this code is executed kbd_init method:
void kbd_init()
  char ack;
[b] kbd.write(0xff);  [/b] // send reset code
,but I´m not sure at all.
Thanks!
Any other ideas?
/Mattias
robtillaart
I;m not sure either as I cannot redo your experiments ;)
But you should at least check the values you get from
ack = kbd.read();
print them like
Serial.println(ack, DEC);
to see what you got. I may or may not be an ACKnowledge char at all...
Rob Tillaart
wespan
Hi, thankyou!
I runned this code
and recived:
-6
and
-86
Any idea´s ?
Best regards
Mattias
