Loading...
Pages: [1]   Go Down
Author Topic: Make my arduino with ATMEGA328P-PU  (Read 1518 times)
Offline Offline
Newbie
View Profile
Hi
I have an Arduino Duemilanove 2009. What I want is after I have programmed the ATMEGA328P-PU, I would like to remove it from the Duemilanove board and to use it alone with whatever component may needed (for example the crystal) in order to minimize as possible the circuit. Has anyone any schematic or PCB for ATMEGA328P-PU ?
I found on internet some but they were for other arduino microcontrollers.
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
Any board that works as an Arduino UNO will also work as an Arduino Diecimila or Duemilanove.  The only difference is which bootloader you use.
Here is one board: http://shop.moderndevice.com/products/rbbb-kit
And another: http://shop.evilmadscientist.com/productsmenu/tinykitlist/74-atmegaxx8
Logged
Central MN, USA
Offline Offline
Faraday Member
Phi_prompt, phi_interfaces, phi-2 shields, phi-panels
View Profile
WWW
You need one ATMEGA328 bootloaded, One 16MHz crystal, 2 22pF cap.
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Plus a 10K pull up resistor on the reset line and a 0.1uF capacitor across power and ground. Also recommended is is a 0.1uF cap from the Aref pin to ground, don't connect this pin to anything else.
Logged
Central MN, USA
Offline Offline
Faraday Member
View Profile
WWW
In that case, let's add a push button for reset and maybe a simple header for serial program upload.
The bootloaded ATMEGA328P-PU are easy to find:
http://adafruit.com/products/123
https://www.sparkfun.com/products/10524?
I even offer them at my store:
http://www.inmojo.com/store/liudr-arduino-and-physics-gadgets/item/atmega328p-with-arduino-bootloader/
I recommend you get a ZIP (zero insertion force) socket too.
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
I think the OP was looking for this, as minimal as it gets.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Build up one of these to keep it small.
http://www.nkcelectronics.com/arduino-runtime-board-rev-b.html
Logged
Central MN, USA
Offline Offline
Faraday Member
View Profile
WWW
Or get an RBBB from modern device.
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Yes, many options. Like Nike says: Just do it.
Logged
Offline Offline
Newbie
View Profile
Thank you Very much ! I will test and I will inform you for the results !
Logged
Pakistan
Offline Offline
Sr. Member
Arduino rocks
View Profile
WWW
you need a breadboard too... smiley-mr-green
Logged
Pages: [1]   Go Up
Print
Jump to:
