Topic: arduino uno error (stk500_getsync(): not in sync: resp=0x00) (Read 5456 times) previous topic - next topic
xal3xhx
i get this error when i try to upload a program. can someone help me plz?
this is the code.
Coding Badly
Do you have the correct board selected on the Tools menu?
Coding Badly
Have you ever successfully uploaded a program to the board?
xal3xhx
no i have not.
but it came with the blink program on it.
Coding Badly
Do you have the correct serial port selected on the Tools menu?
xal3xhx
yes.
there is only one.
for me it is com1.
i ma runing windows 7.
Coding Badly
When you connect the Uno to the computer, is the "device insertion" sound output?
xal3xhx
Coding Badly
Have you followed the instructions here...
http://arduino.cc/en/Guide/windows
xal3xhx
no idid not do that right give me a min i will see if that works.
Munirul
I bought 4 $5 dccduino from ebay, two of them worked right out of the box, while other two refused to work with "not in sync resp=0x0" error. dccduino requires drivers from their chinese site, I ended up installing them on a WinXP VM. Anyway, was about to give up hope for other two clones, assumed hardware issue, as some has mentioned above. What worked for me is using one of the working dccduino as ISP (see Arduino as ISP tutorials), after burning bootloader and deploying blink sketch they started working. They would now work directly connecting via usb, no need for Arduino as ISP after first attempt.
ChilliTronix
The  dccduino uses a CH340 USB to serial converter. It takes different USB drivers.
