Topic: Debounce. (Read 920 times) previous topic - next topic
xxryan1234
Can we debounce a microphone? :)
James C4S
Why would you bounce it in the first place?
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
xxryan1234
the output values given are spiking up and down in the serial monitor if it detects blow,.
generally the mic i have been doing is a blow sensor.
i want to make the reading high if it detects blow, and low if otherwise.
does software debounce gives me the result i want to?
xxryan1234
...and does software debounce applicable in the mic?
James C4S
What do you think debounce is?
xxryan1234
as what i have learned sir, when i use debounce on switch/buttons, debounce eliminates the bouncing of the switches and making sure that one digital signal can be registered within the duration of a given time. am i right thinking this? is the debounce useful in my mic module?
James C4S
Switch debouncing works because switches physically bounce.
Microphones don't bounce.
PeterH
Debounce is a reasonable term for what you are trying to do, but this is not typical debouncing. Debouncing usually consists of waiting for an input to settle into a steady state so that transient changes are suppressed. In your case you would need a different algorithm, because in effect what you're really trying to do is smooth an intermittent signal. You will need to decide what constitutes 'blow'. Do you trigger on a single spike, or on a number of spikes close together, or what?
I only provide help via the forum - please do not contact me for private consultancy.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
