Author Topic: [SOLVED] Is there any way to attach -D from within arduino IDE  (Read 1133 times)
Central MN, USA
I am trying to attach a -Ddisable_simple_fns option to the compiler command that arduino IDE generates automatically. Is there a way to do it? Thanks. It would be nice to have this hack "custom def" in arduino IDE although I don't know how to.
[Edit]: The solution appears to require either visual studio plugin or arduino 1.5 and creating new board def in boards.txt with a "board_name.build.extra_flags=-Dsomething=value".
« Last Edit: December 28, 2012, 01:26:36 pm by liudr » Logged
Dallas
Online Online
Shannon Member
I believe IDE 1.5 reads the command-lines from platform.txt.
Edit: Remove plural.
« Last Edit: December 28, 2012, 02:59:35 am by Coding Badly » Logged
Central MN, USA
Thanks. I will put IDE upgrade on my agenda once I'm done with work at hand. I am using 1.0 right now.
North Queensland, Australia
I believe IDE 1.5 reads the command-lines from platforms.txt.
Hey, i'm using 1.5.1r2 I cannot find a 'platforms.txt',
I also had a browse through the IDE preferences ( C:\Users\Chris\AppData\Roaming\Arduino ) but no luck. Would be very nice if I could change the optimisation levels.
Any locations I should be looking in?
EDIT: windows search is blind ( the machine's fault not the user  smiley-razz ), it was in "D:\arduino-1.5.1r2\hardware\arduino\avr"
« Last Edit: December 28, 2012, 02:26:45 am by pYro_65 » Logged
Dallas
Online Online
Shannon Member
Sorry about that.  The filename is platform.txt (singular; not plural).
« Last Edit: December 28, 2012, 02:59:12 am by Coding Badly » Logged
IDE for Microsoft Visual Studio and Atmel Studio 6.1 (in beta), optional USB Debugger
It's in the exeFolder/hardware/arduino/avr and can work in conjunction with the new properties in the 1.5 boards.txt
Alternatively if you want it to work with 1.0.x formats then the visual studio plugin allows any number of -D defines via the project property "Defines - Project"
But 1.5 might be the simplest route unless you also want intellisense etc and are using windows.
« Last Edit: December 28, 2012, 10:22:17 am by Visual Micro » Logged
Arduino for Microsoft Visual Studio Pro (and Atmel Studio 6.1 in beta) http://www.visualmicro.com
Arduino Debugger http://www.visualmicro.com/post/2012/05/05/Debug-Arduino-Overview.aspx
Central MN, USA
Where do I get this visual studio plugin?
Download via the main site here
You need a copy of Visual Studio Pro. This page shows how to get a copy for free
If you have any questions or want the serial debugger upgrade then register for the forum
Central MN, USA
Is it only possible to modify boards.txt to add another def in 1.5?
Thanks for the visual studio link.
I've only recently started with 1.5 so can't recall exactly but I think you can add your own overrides and "recipe" patterns directly to the boards.txt. You will find the default settings and recipe patterns in the platform.txt. Example:-
recipe.cpp.o.pattern=
So this would mean you could copy a board def in the boards.txt, change the name to whatever you want and add your own recipe specifically for your new board definition. This would allow you to optionally invoke your additional compiler defines just by switching board. (I hope this info is correct)
If you have vs installed then it is certainly easier to achieve this with the vs plugin, which also allows us to set a -D list on a per configuration basis. This means, for example, that we can have a -D list for "My Normal Compile" and a list for "My Special Compile" etc.
EDIT: How to copy a board def - Example
Below is the def for the Uno
uno.name=Arduino Uno
uno.upload.tool=avrdude
uno.upload.protocol=arduino
uno.upload.maximum_size=32256
uno.upload.speed=115200
uno.bootloader.tool=avrdude
uno.bootloader.low_fuses=0xFF
uno.bootloader.high_fuses=0xDE
uno.bootloader.extended_fuses=0x05
uno.bootloader.unlock_bits=0x3F
uno.bootloader.lock_bits=0x0F
uno.bootloader.file=optiboot/optiboot_atmega328.hex
uno.build.mcu=atmega328p
uno.build.f_cpu=16000000L
uno.build.core=arduino
uno.build.variant=standard
Below is a duplicate called Arduino Uno 2. Notice that each property for the board starts with a unique id, in this case "uno2". So to copy a def you only need to set the .name property and ensure that each entry starts with a unique id of your choice.
uno2.name=Arduino Uno 2
uno2.upload.tool=avrdude
uno2.upload.protocol=arduino
uno2.upload.maximum_size=32256
uno2.upload.speed=115200
uno2.bootloader.tool=avrdude
uno2.bootloader.low_fuses=0xFF
uno2.bootloader.high_fuses=0xDE
uno2.bootloader.extended_fuses=0x05
uno2.bootloader.unlock_bits=0x3F
uno2.bootloader.lock_bits=0x0F
uno2.bootloader.file=optiboot/optiboot_atmega328.hex
uno2.build.mcu=atmega328p
uno2.build.f_cpu=16000000L
uno2.build.core=arduino
uno2.build.variant=standard
« Last Edit: December 28, 2012, 01:32:06 pm by Visual Micro » Logged
Central MN, USA
I've only recently started with 1.5 so can't recall exactly but I think you can add your own "recipe" pattern directly to the boards.txt. You will find the default "recipe" patterns in the paltform.txt
It's certainly easier to achieve this with the vs plugin which also allows you to set a -D list on a per configuration basis. Hence you can have a -D list for "My Normal Compile" and a list for "My Special Compile" etc.
Thanks. I added a new line phi_panel.build.extra_flags=-Ddisable_simple_fns to a new board def I copied and changed and it did the trick, according to the verbose output. I wonder if I can do phi_panel.build.extra_flags=-DXX=10 with the defined number instead of just defining a name. Will try later.
phi_panel.name=Phi panel
phi_panel.upload.tool=avrdude
phi_panel.upload.protocol=arduino
phi_panel.upload.maximum_size=32256
phi_panel.upload.speed=115200
phi_panel.bootloader.tool=avrdude
phi_panel.bootloader.low_fuses=0xFF
phi_panel.bootloader.high_fuses=0xDE
phi_panel.bootloader.extended_fuses=0x05
phi_panel.bootloader.unlock_bits=0x3F
phi_panel.bootloader.lock_bits=0x0F
phi_panel.bootloader.file=optiboot/optiboot_atmega328.hex
phi_panel.build.mcu=atmega328p
phi_panel.build.f_cpu=16000000L
phi_panel.build.core=arduino
phi_panel.build.variant=standard
## recipe.cpp.o.pattern="{compiler.path}{compiler.cpp.cmd}" {compiler.cpp.flags} -mmcu={build.mcu} -Ddisable_simple_fns -DF_CPU={build.f_cpu} -D{software}={runtime.ide.version} {build.extra_flags} {includes} "{source_file}" -o "{object_file}"
Great. I don't see why you can't do that. The extra flags are just passed to the compile statement without change, so should work fine.
Central MN, USA
Yep, everything I typed in there gets appended to the compiler options. Thanks for helping me through! Karma for you!
