Loading...
Pages: [1]   Go Down
Author Topic: Arduino ethernet to digital pins  (Read 249 times)
GTA, Canada
Offline Offline
Newbie
The power is in the code.....
View Profile
Well there is a possibility that I'm just blind, however I have not been able to find an answer to this issue. Is it possible to access the serial pins or any other digital pins through the ethernet shield as a virtual serialport? I'm helping someone setup a remote control paintball turret. It currently is controlled from a vb.net application with a joystick, through the serial port. Serial port -> Xbee -> Xbee -> Arduino. There is video feedback via WIFI from a web cam. If possible, I'd like to eliminate the xbee and just go through wifi. Computer -> Wifi Router-> Arduino Ethernet shield. It would be very easy to just access it as a virtual serial port, that way I wouldn't have to worry about rewriting the vb.net code.
Any thoughts?
Thanx
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Access pins, and reading serial data, as both possible.
Quote
Start worrying. The Ethernet shield is not an extension of the serial port.
The Arduino with Ethernet shield is either a client, periodically polling a server for information, or it is a server, periodically responding to GET requests.
You most likely want the Arduino to act as a server, responding to GET requests. The GET request will convey additional information that tells the Arduino what to actually do,
That is going to require a major rewrite of the VB application.
Logged
0
Online Online
Tesla Member
Arduino rocks
View Profile
Quote
As long as the the joystick is connected to the computer, the computer will have to be running some type of program to support the activity. If you want to use the ethernet module for lan/wan connections, the probable communication choises  would be http, telnet, and UDP protocol. You would need to develop the appropriate application on the pc to support these. The arduino with an ethernet shield would have a server application to respond to the commands from the pc.
Logged
Why I like my 2005 rio yellow Honda S2000 with the top down, and more!
GOOGLE ADVANCED FORUM SEARCH BELOW!
Go to:  http://www.google.com/advanced_search?hl=en
put in key search words,
use site or domain:  http://arduino.cc/forum
or in a google search box put key words site:http://arduino.cc/forum
Pages: [1]   Go Up
Print
Jump to:
