Loading...
Pages: [1]   Go Down
Author Topic: 74HC595 driving 12V RGB ledstrips  (Read 361 times)
Offline Offline
Full Member
View Profile
WWW
Hi!
I would like to drive 5x 12V RGB ledstrips (only 5x3 leds) on 2x 74HC595 shiftregisters (using
the ShiftPWM library). The ledstrips have an common anode. They should stay individual
addressable.
Do I have to use transitors for each R,G,B line of all the 5 ledstrips?
That would be 15 transistors on the pcb!? smiley-sad Is there a better solution?
Regards and thanks in advance!
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Quote
If using a 74HC595 then yes.
Quote
Yes.
Quote
Depends on how you define better, lower cost or lower component count?
What current does each of these strips take? That will determine your other choices.
Logged
Offline Offline
Full Member
View Profile
WWW
Thanks for your reply!
I think "better" would be less component count. I dont have much space
since Im bulidng a little mood lamp.
I saw the ULN2803 but that chip would assume that the strips have a
common kathode, right?
Each strip takes approximately max. 30-40mA while fading through all
possible colors.
Logged
Offline Offline
Brattain Member
View Profile
WWW
Quote
No that is a current sink so it assumes you have a common anode strip.
Quote
possible colors.
Are you sure? It doesn't sound much, one LED normally takes 20mA, you need to know the maximum current and you need to know it precisely.
Logged
Offline Offline
Full Member
View Profile
WWW
Quote
So that means that I can connect the outputs of the chip directly to the kathode of each R,G,B lines?
Sorry... to be honest in the ULN2803 schematics I believed that the chip has common GND and
all the outputs are positive.  smiley-red Do you think I can use that chip?
Quote
Are you sure?
Hmm... I thought fading through all colors would give an good average of the current. Its actually jumping between values and
I saw 30-40mA max.
At what color would be the max. current? All PWM ports on 255?
Sorry for my noobienes  smiley-confuse
« Last Edit: December 28, 2012, 07:41:08 am by asuryan » Logged
Offline Offline
Full Member
View Profile
WWW
I measured with all RGB ports set to 255 without fading and
I get 47.5mA for one RGB strip.
The strip is rated at 1.2A when 1 meter (100cm) is lighted but im using just 5cm. So
converting the current would assume:
1200mA/100cm = 12mA -> 1cm = 12mA -> 5cm = 60mA
« Last Edit: December 28, 2012, 07:58:27 am by asuryan » Logged
Offline Offline
Brattain Member
View Profile
WWW
Quote
No all the outputs are not positave, the outputs pull down to ground. That is the output switches between being connected to ground and being connected to nothing. There is no voltage output from this chip.
That current looks better.
There are lots of chips you can use at that sort of current. Iin addition to the one above you can also use a TLC5940.
Logged
Offline Offline
Full Member
View Profile
WWW
Thanks Mike for your help! smiley
Should I put limiting resistors before the inputs of the ULN2803 or
could I directly route the traces from the 74HC595 to these inputs?
Im just curious:
What purpose has pin 10 (COM) of the ULN2803 if not VCC?
Logged
United Kingdom
Offline Offline
Faraday Member
View Profile
WWW
Use TPIC6B595 shift registers instead of 74HC595. They can drive your common-anode LEDs directly, all you need is the series resistors.
Logged
Formal verification of safety-critical software, software development, and electronic design and prototyping. http://www.eschertech.com
Offline Offline
Brattain Member
View Profile
WWW
Quote
It is the common connection for the reverse bias diodes used when switching inductive loads. Normally you have no need to connect pin 10 unless you are driving things like a motor.
Quote
It depends on how you are wiring things and how you are driving the multiplexer. Generally the resistor goes in the line that will see only one LED on at any one time.
Logged
Pages: [1]   Go Up
Print
Jump to:
