Loading...
Pages: [1]   Go Down
Author Topic: SerialEvent improvement  (Read 747 times)
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
In version 1.0 after loop() has finished serialEventRun is called to make serial events possible (see main.cpp below)
Code:
#include <Arduino.h>
int main(void)
init();
setup();
for (;;) {
loop();
if (serialEventRun) serialEventRun();
return 0;
Code:
void serialEventRun(void)
#ifdef serialEvent_implemented
  if (Serial.available()) serialEvent();
#endif
#ifdef serialEvent1_implemented
  if (Serial1.available()) serialEvent1();
#endif
#ifdef serialEvent2_implemented
  if (Serial2.available()) serialEvent2();
#endif
#ifdef serialEvent3_implemented
  if (Serial3.available()) serialEvent3();
#endif
I think it would improve if the number of bytes available were passed as a parameter to serialEvent(int bytes);
That way it would not be necessary to check the available bytes in the event handler again.
If one wants to handle a single byte/char => just ignore the param
So I propose something like (removed defines for readability)
Code:
  uint8_t count = Serial.available()
  if (count ) serialEvent(count );
  count = Serial1.available()
  if (count) serialEvent1(count);
  count = Serial2.available()
  if (count) serialEvent2(count);
  count = Serial3.available()
  if (count) serialEvent3(count);
Opinions why this is a bad idea?
« Last Edit: December 27, 2012, 11:06:39 am by robtillaart » Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Quote
Aside from the while idea of serialEvent() as a callback being silly, I see nothing wrong with passing the number of bytes available to the callback.
I'd prefer to see the use of an optional pointer, so the callback definer can define whether to be told, or not. But, that's rather confusing to newbies, so I wouldn't make it any kind of priority to do it that way.
Of course, the number of bytes available could change between when it is determined in loop() and when the callback is entered, especially at high baud rates.
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
Quote
Good point Paul,
So the parameter will give the number of bytes that are at least in the buffer, if the #bytes has increased in the mean time, they will be noticed in the "next event" OR the implementer of SerialEvent() must decide to call Serial.Available() anyway. Which I just wanted to prevent with this proposal because it was called to check if SerialEvent() had to be called anyway
point taken
Thanks,
Logged
Rob Tillaart
nr Bundaberg, Australia
Offline Offline
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
View Profile
WWW
You will always have the chance of available() returning < the actual chars available, obviously with a function call between reading and using there's more chance but the issue is always there.
I see no problem with this, you either get those chars next time or if it really matters (unlikely) do another call to available().
______
Rob
Logged
Rob Gray aka the GRAYnomad http://www.robgray.com
Netherlands
Offline Offline
Tesla Member
View Profile
The idea is posted as a proposal here - https://github.com/arduino/Arduino/issues/1190 -
Logged
Rob Tillaart
Pages: [1]   Go Up
Print
Jump to:
