Loading...
Pages: 1 [2]   Go Down
Author Topic: Melodien Soundsequenzen mit dem arduino wieder geben  (Read 974 times)
Offline Offline
Newbie
View Profile
so da ich mit dem PROGMEM nicht weiter komm ( leuft net ) kam ich auf die idee die daten auf einer sd karte zu speichern so kan ich diese auch wariiren ? was wird dafür benötigt ?
Logged
Offline Offline
Edison Member
View Profile
Wo klemmt es denn bei Zugriff auf die PROGMEM Daten? Code? Fehlermeldungen?
Logged
Offline Offline
Newbie
View Profile
Also der folgende Code läuft einwandfrei und begrüßt dich sogar! ...  smiley-mr-green Die Ausgabe erfolgt über Pin 11, Pin 10 dient mir nur als Masse, weil ich gerade nur einen Speaker mit 2-Pin-Stecker zu Hand habe ...
Code:
PROGMEM byte snd[] ={128,129,129,129,129,128,125,125,128,128,129,131,130,
127,127,125,124,128,132,131,129,128,126,127,131,129,125,126,129,129,130,130,129,127,128,127,125,127,129,130,129,128,127,128,
129,128,127,127,129,129,129,126,124,125,128,130,132,132,129,128,127,123,121,124,128,132,135,134,129,124,122,122,126,132,133,
131,129,126,124,125,128,131,132,130,126,124,126,128,130,129,126,124,126,128,130,130,130,129,128,126,125,126,126,129,132,130,
128,126,123,124,130,133,132,129,126,125,126,127,127,127,127,130,133,132,127,123,122,125,130,132,132,132,132,129,126,123,124,
129,131,130,126,125,130,134,133,128,125,126,131,132,128,125,125,128,131,132,130,128,129,130,130,131,130,128,128,129,128,127,
127,128,128,131,128,125,125,128,129,129,127,122,121,122,122,125,126,125,127,128,124,122,124,125,129,130,122,119,122,126,130,
133,129,126,131,132,130,133,133,130,133,136,134,133,136,137,140,143,139,136,138,141,139,138,137,134,135,136,132,129,127,125,
124,123,121,120,121,119,113,109,107,109,113,110,105,103,107,111,114,113,109,111,127,141,141,136,125,119,122,128,128,128,131,
132,136,140,140,138,142,145,145,149,152,150,148,144,140,140,145,146,148,148,147,145,142,136,130,127,125,125,124,120,114,110,
105,102,99,94,94,97,97,97,97,106,126,143,147,139,126,115,114,118,121,123,126,129,134,139,137,132,129,130,132,132,131,
129,129,133,137,139,139,141,143,147,153,156,153,148,143,140,141,144,145,145,145,145,144,140,132,126,124,122,119,113,106,100,
95,91,88,89,91,91,92,98,116,145,164,159,136,114,104,107,115,117,117,120,132,144,148,143,133,126,127,130,129,127,127,
129,133,137,136,134,137,141,147,150,152,154,154,150,146,142,141,144,146,146,145,145,143,138,131,124,119,114,109,104,102,98,
92,86,82,82,84,87,97,127,160,169,158,137,114,106,110,109,105,108,117,131,149,153,145,139,136,134,131,125,118,118,128,
138,140,139,136,133,137,143,144,146,149,152,153,152,150,146,144,144,144,145,147,145,142,138,133,127,121,114,106,99,95,95,
98,92,87,86,83,84,90,113,151,170,163,143,126,118,120,115,101,95,105,121,140,149,145,141,147,155,152,135,115,106,112,
123,128,127,128,136,147,154,153,149,146,147,150,149,144,143,145,148,148,147,145,146,146,143,138,132,125,116,107,99,93,94,
97,94,89,88,87,87,89,88,111,155,171,161,146,130,124,131,120,97,88,98,113,133,141,136,146,166,172,159,138,115,108,
114,112,105,107,118,135,154,162,161,162,164,160,153,142,131,132,138,140,143,147,151,155,155,148,140,133,127,118,107,95,90,
93,95,91,87,86,88,90,87,83,108,151,161,156,148,139,142,149,133,107,97,97,104,115,115,111,129,155,169,169,159,144,
142,143,128,109,99,97,105,116,121,126,144,165,179,183,177,167,162,157,144,132,125,125,129,135,134,136,140,141,139,133,122,
113,106,96,88,81,72,67,67,70,70,87,130,156,160,164,163,163,173,162,131,111,102,93,92,89,79,93,122,145,159,166,
166,170,177,167,143,126,112,105,102,94,88,98,123,144,161,172,179,187,192,183,168,155,144,137,130,121,114,115,118,119,120,
119,117,118,118,113,105,97,85,74,68,62,61,89,120,130,137,150,158,175,183,165,146,140,128,117,105,86,77,92,108,118,
126,135,146,164,173,165,154,150,144,138,128,111,103,109,118,125,131,139,151,165,173,172,171,170,168,162,151,140,132,127,119,
112,106,103,102,102,99,97,98,96,90,84,80,77,77,102,127,129,131,142,146,162,170,155,140,139,133,125,118,102,92,103,
114,118,122,126,132,146,155,151,144,145,144,143,139,127,119,125,130,132,135,137,142,154,159,159,161,163,163,163,156,148,144,
139,130,123,116,108,104,101,94,90,88,86,80,78,77,78,81,103,126,127,130,142,148,161,170,158,145,145,140,131,123,110,
99,104,112,113,113,116,120,132,144,143,140,144,148,149,150,142,134,134,135,132,130,131,132,139,144,147,151,157,160,162,162,
158,154,151,144,135,127,120,112,105,98,92,88,88,84,79,76,75,72,76,102,122,122,127,139,144,162,174,162,152,152,148,
142,137,120,103,106,113,110,109,107,107,118,133,133,131,136,141,148,156,152,143,143,145,142,139,136,131,135,142,140,141,146,
149,152,156,154,151,152,149,142,136,128,120,115,109,101,96,94,90,86,82,79,77,75,85,107,112,111,123,133,142,161,162,
156,154,159,155,153,145,130,118,123,122,114,109,105,102,111,122,120,119,125,131,139,147,145,140,143,149,150,149,145,140,143,
150,150,145,143,142,145,148,146,139,138,139,139,136,131,122,118,117,113,107,102,96,91,88,84,78,74,84,103,103,104,117,
121,131,154,156,149,153,158,156,159,155,141,129,132,130,122,117,113,103,109,118,115,113,117,119,122,135,140,137,138,145,146,
150,154,150,147,153,154,150,150,147,140,141,145,139,135,137,134,131,133,134,132,120,114,111,104,98,87,73,67,62,57,76,
109,110,113,131,143,157,181,185,166,155,159,149,139,131,107,86,92,105,99,96,104,108,123,152,163,156,153,159,159,161,160,
138,116,115,119,116,117,119,120,132,156,170,172,176,177,177,177,172,153,135,127,118,109,99,88,79,77,81,79,78,78,74,
76,80,88,125,152,156,158,160,162,164,173,157,129,108,98,95,94,96,89,85,104,125,142,153,159,160,163,172,170,159,143,
128,117,112,112,107,101,103,109,121,136,149,154,159,165,171,173,172,167,158,151,146,139,132,124,116,109,103,97,92,87,83,
79,79,80,82,87,99,115,130,147,154,158,161,166,166,162,156,143,128,119,113,106,100,96,91,92,101,114,122,131,138,145,
153,162,166,162,155,147,139,131,125,116,104,97,95,96,102,110,117,124,135,148,159,167,172,171,167,164,161,153,144,136,126,
121,120,119,120,120,123,125,128,128,124,117,111,106,101,96,89,85,84,91,106,122,131,137,142,148,156,164,166,159,147,137,
127,123,120,113,102,94,94,99,109,121,129,132,136,144,152,159,162,157,146,136,129,122,118,112,105,97,95,100,107,118,129,
137,143,152,162,167,170,169,162,152,146,140,133,128,123,118,115,118,122,127,132,136,136,135,133,126,119,111,103,94,85,80,
79,83,94,110,124,135,145,151,156,163,168,167,160,149,135,122,113,109,103,98,96,95,99,108,121,132,143,150,154,155,157,
157,153,147,138,125,113,105,101,98,99,102,104,109,117,127,138,151,161,165,167,166,162,156,151,144,135,128,121,116,115,117,
120,124,130,134,136,141,144,143,141,136,127,117,106,95,84,78,75,76,82,96,113,128,143,155,160,165,167,167,164,158,148,
133,120,108,98,93,93,95,98,105,112,121,132,144,153,160,163,161,155,149,140,131,122,114,107,100,96,96,98,105,114,123,
132,142,149,155,159,162,162,161,157,149,139,132,124,118,117,117,119,121,125,129,134,139,142,144,145,142,137,131,124,116,107,
99,91,83,79,78,83,96,113,131,147,159,163,164,163,160,157,153,147,137,125,112,99,91,89,92,99,110,120,127,134,140,
146,151,157,160,159,154,144,131,118,109,103,100,101,104,106,110,113,119,127,137,147,155,160,160,155,149,142,135,132,129,126,
124,121,119,118,120,123,130,137,143,148,149,148,147,143,139,135,131,125,119,112,105,99,96,94,94,97,99,102,108,117,129,
142,153,161,163,161,154,145,136,129,123,118,115,111,108,104,103,104,109,118,128,138,147,151,152,149,145,140,136,133,129,125,
120,114,109,105,104,107,113,121,130,137,142,145,145,145,144,142,140,139,135,130,124,119,115,113,116,120,128,135,141,145,147,
147,146,145,144,143,141,139,134,130,125,120,117,115,113,113,112,113,112,112,112,112,112,112,114,118,123,131,138,144,147,147,
144,139,134,129,125,123,122,121,120,119,117,116,116,118,121,127,133,138,141,142,141,138,134,130,127,125,124,123,122,121,119,
118,117,118,121,126,131,136,140,141,141,139,137,134,131,128,127,126,124,123,121,120,120,121,125,130,137,143,148,150,149,147,
143,139,135,132,130,129,128,126,126,123,122,121,121,122,121,121,120,118,116,114,112,110,110,111,115,120,128,135,141,145,146,
145,141,137,132,127,125,123,121,120,119,117,116,115,116,119,124,130,136,141,143,144,142,138,134,129,125,123,121,120,119,119,
118,119,119,121,124,129,134,138,141,143,142,139,136,131,127,123,121,119,119,119,120,120,121,123,125,128,132,136,140,144,146,
147,147,144,141,137,132,129,126,124,124,124,125,127,129,131,132,132,133,132,130,128,124,120,116,112,109,106,105,105,106,110,
116,123,132,140,147,151,152,150,145,139,131,125,119,116,114,114,114,114,116,117,120,124,129,135,141,145,147,147,144,139,132,
126,121,116,114,113,114,116,119,122,125,127,130,133,136,139,142,142,142,139,134,129,124,119,116,115,115,117,120,124,127,130,
133,135,136,137,138,139,138,138,138,136,134,133,130,129,128,127,127,128,129,130,132,134,135,135,135,134,133,131,129,126,123,
119,115,112,110,108,108,108,109,111,114,119,125,133,140,146,150,150,148,143,136,127,121,115,112,112,113,116,118,121,123,126,
129,132,135,139,142,143,143,141,136,130,124,118,114,112,112,115,119,123,127};
#define PWM_Pin 11
#define GND_Pin 10
//---------------------------- setup ---------------------
  int pwm_freq=1;
  TCCR2B = (TCCR2B & 0xF8) | pwm_freq;
  pinMode(PWM_Pin, OUTPUT);
  pinMode(GND_Pin, OUTPUT);
  digitalWrite(GND_Pin, LOW);
//---------------------------- loop ----------------------
{ byte b;
  for (int i=0; i<sizeof(snd); i++)
     b = pgm_read_byte(&snd[i]);
     analogWrite(PWM_Pin,b);
     delayMicroseconds(120);
delay(2000);
« Last Edit: January 02, 2013, 03:03:01 pm by qualidat » Logged
Offline Offline
Newbie
View Profile
Was ist los, Sprache verschlagen?
Logged
Offline Offline
Newbie
View Profile
tut mir leid das ich mich jetzt erst wieder melde war verhindert mittlerweile läuft es =)
bin jetzt fleißig am schneiden von den sounddaten
Logged
Offline Offline
Newbie
View Profile
So nun läuft mal die Wiedergabe ganz gut nun hab ich ein neues Problem da ich den arduino in ein RC Truck baue und auch per Empfänger Gesteuert werden soll
ich habe in das Programm ein "pulseIn" eingebaut um das PWM des Empfängers auszulesen wie ich es schon oft gemacht hatte doch anscheinend verlangsamt das den Prozessor so sehr das nur ein gekratzte rauskommt und kein anständiger ton mehr.
habt ihr eine idee wie ich das mache das es geht ?
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
