int pin_B = 0;
int pin_X = 1;
These are the serial pins, you know. If you are doing Serial I/O (and you are), you can't expect to use them with LEDs, too.
I'm not using them to drive LEDs they're integrated with a USB game controller the game controller simply needs a logic high or logic low.
I know when the Arduino is "pushing" a button because I have the controller plugged into my computer with a simple test program that shows when a button is being pushed.
when I run my new function instead, which loops through an array and should be doing the exact same thing as "doStuff" the pin for pin_B, and pin_X don't work...
Well, I'm not surprised.
I still don't understand, maybe you could explain to me why these outputs work as desired when I call
"digitalWrite(pin_B, LOW);" in the "doStuff" function but not when I call
"digitalWrite(pin_B, LOW);" in the "runSeq" function.
