Loading...
Pages: [1]   Go Down
Author Topic: Reaction Test  (Read 445 times)
Offline Offline
Newbie
View Profile
Hey.
Im new to this arduino stuff and i'm sitting on some code that i think should work. the idea is sort of a reaction tester where a red LED blinks on for one second with random intervals. if a button is pressed while the red LED is still on the red LED turns off and a green one goes on.
can anyone help and point out where i've gone wrong. :/
Code:
int Correct=12;
int LED=2;
int Button=4;
 pinMode(Correct, OUTPUT);
 pinMode(LED, OUTPUT);
 pinMode(Button, INPUT);
   if(digitalRead(LED,HIGH);
     if(digitalRead(Button,HIGH))
    digitalWrite(LED,LOW);
    digitalWrite(Correct,HIGH);
    delay(2000)
    digitalWrite(Correct,LOW);
 delay(random(2000,4000));
  digitalWrite(LED,HIGH);
when i go to compile it just points me at this line
if(digitalRead(LED, HIGH);
Any help would be appreciated  smiley
Moderator edit: [code] [/code] tags added.
« Last Edit: December 28, 2012, 03:56:47 pm by Coding Badly » Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
when you call delay(1000) the user can press any button as much as he wants but his button is never tested when the LED is on.
Check the blink without delay example (tutorials) to get an idea how this app should be solved.
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
Fix the formatting of the line
Code:
if(digitalRead(LED) == HIGH){
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Offline Offline
Newbie
View Profile
Thanks il rectify the code and see if it works smiley ta
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Of course, you are reading an output pin there, and the last thing you do in void loop is write it Low, so I doubt you'd ever see it high.
Logged
Pages: [1]   Go Up
Print
Jump to:
