Topic: Sending SMS using ICOMSAT 1.1 and UNO (Read 1 time) previous topic - next topic
uydarp
Hi all,
i wish to control a servo motor using a phone call, when i call from a particular mobile number the servo motor should rotate 90. For this i bought a UNO and a ICOMSAT V1.1 GSM/GPRS shield.
I have no idea of ICOMSAT and how it works, I would like to learn about ICOMSAT, i want to know where to start.
I need some website explaining how i have to connect ICOMSAT to UNO, And step by step tutorial for sending SMS using the same.
Your advice is much appreciated.
Thanks in advance.
PeterH
If you're starting from zero, I suggest that Google would be a good first step.
uydarp
Tried that, if you could suggest some book r something that will be great. Thanks for the reply.  :)
phillipsmax1
a good start before using a icomsat is starting with the basics look at amazon.com or arduino.cc for books they have some good starters. also the ICOMSAT using GSM_SHIELD.h Library plus a minor modification in that library to get it to work with the uno. But that will get you started in the right step.
