Loading...
Pages: 1 [2]   Go Down
Author Topic: Help with programming a motor controller  (Read 533 times)
Offline Offline
Newbie
View Profile
Solution has been found for anyone else that encounters the same problem.
Code:
digitalWrite(3,HIGH);
pinMode(3,OUTPUT);
delay(10); // gives the motor controller plenty of time to start up
 //Four byte motor controller command
 Serial.write(10000000); //Start byte
 Serial.write((byte)0); //Device type
 Serial.write(00000101);// Motor number and direction
 Serial.write(01111111);//Motor speed 0-127
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
I find that a little hard to believe. The documentation describes binary values for the command byte. That is NOT a binary value you are passing for the command byte. The 3rd and 4th are octal values. Why you chose base 8 when the documentation uses binary (base 2) needs explaining.
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
