Author Topic: Data in progmem - not working - why?  (Read 302 times)
Hi all,
I made a little bitmap image that I want to send to a VFD display. The image is 128 x 64 pixels, therefore 8192 / 8 or 1024 bytes.
Of course, I want to put it into PROGMEM, and that's where my problem is.
Here's the code:
#include <avr/pgmspace.h>
void loop(void) { ; }
uint8_t PROGMEM image[] = {
        0xf8,0x7f,0xff,0xff,0xf0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7d,0xfe,0x7d,0xed,
        0xfc,0x83,0xff,0xff,0xc0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x37,0xfd,0xf3,0xd9,
        0xfc,0x04,0xff,0xff,0x80,0x09,0x00,0x00,0x00,0x00,0x00,0x00,0x2f,0xfd,0xb5,0x7c,
        0xfc,0x80,0x1f,0xfe,0x00,0x41,0x00,0x00,0x20,0x00,0x00,0x00,0x1f,0xfb,0xe7,0xed,
        0xfe,0x02,0x57,0xf4,0x93,0x0e,0x20,0x00,0x00,0x00,0x00,0x00,0x1f,0xfb,0xef,0x7c,
///////-----snip -- left out a big chunk in the middle for brevity
        0x59,0xa0,0x05,0xff,0x8a,0x00,0x10,0x00,0x00,0x49,0x25,0x86,0xc0,0xab,0x60,0x0f,
        0x46,0x58,0x0b,0xff,0xd8,0x00,0x81,0x20,0x03,0x6f,0xda,0x68,0x72,0x54,0x88,0x0f,
        0x69,0x60,0x3b,0xce,0xc0,0x00,0x08,0x00,0x35,0xba,0x29,0x23,0x09,0x96,0xfc,0x07,
        0x16,0xa0,0x5a,0x50,0x72,0x00,0x20,0x80,0x96,0xcd,0xd5,0x94,0xaf,0xd2,0x4c,0x07,
        0xd1,0xa0,0xb2,0x90,0xc0,0x00,0x00,0x02,0x75,0xb6,0x96,0x52,0x4f,0xed,0x9e,0x93,
        0x2d,0x60,0x79,0x01,0x00,0x00,0x00,0x15,0x9b,0xda,0xd9,0x48,0x9f,0xf9,0x5c,0xf3,
        0x93,0xb0,0x00,0x80,0x00,0x00,0x09,0xaa,0x6e,0xed,0x2d,0x25,0x7f,0xbe,0x42,0xf7
void setup(void)
        char buffer[8];
        const char *mask = "0x%02X, ";
        uint8_t data;
        uint16_t x;
        for (x = 0; x < 1024; x++) {
                data = pgm_read_byte(image[x]);
                sprintf(buffer, mask, data);
                Serial.print(buffer);
                if (((x+1) % 16) == 0) {
                        Serial.print("\r\n");
Now, of course, I would expect the first few lines to look like this:
        0xF8, 0x7F, 0xFF, 0xFF, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7D, 0xFE, 0x7D, 0xED,
        0xFC, 0x83, 0xFF, 0xFF, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x37, 0xFD, 0xF3, 0xD9,
... but it comes out like this:
        0x0C, 0xDD, 0xDD, 0xDD, 0x00, 0x05, 0xDD, 0x0C, 0x0C, 0x0C, 0xDD, 0xDD, 0xDD, 0xDD, 0xDD, 0xDD,
        0xDD, 0xDD, 0xDD, 0xDD, 0xDD, 0xDD, 0xDD, 0xDD, 0xDD, 0xDD, 0xDD, 0xDD, 0xDD, 0xDD, 0xDD, 0xDD,
Anyone have an idea what I'm doing wrong???
Thanks!
-- Roger
Get Bitlash: http://bitlash.net
Instead of this construct, which I haven't seen before:
…what happens if you try this:
data = pgm_read_byte(image + x);
-br
Dallas
Shannon Member
Or this...
data = pgm_read_byte( & image[x] );
Or this...
  • );[/font]
Both your example and Billroy's example work. Which tells me that "image" is a POINTER........
Thanks and karma++ for both.
-- Roger
Seattle, WA USA
Online Online
Seattle, WA USA
No. image is an array. There are strong similarities between arrays and pointers, but there are (subtle) differences, too.
Funny thing is, if I put the data in a "regular" array (i.e. const char *image = "0x00, 0xff....."smiley-wink I can access individual bytes with "image
  • " syntax. But if it's in progmem, then "image" acts like a pointer (i.e. "image + 0" is the first element, as well as "&image[0]").
I've been programming in C and C++ for years, so the occasional "odd" things I have to do for AVR programming sometimes throws me a curve.
Anyway, I've got it all working and I see what's going on, so it's another problem solved and another byte or two of new data to store in my brain!  smiley
Thanks!
-- Roger
Seattle, WA USA
Online Online
Seattle, WA USA
and another uint8_t or two of new data to store in my brain!
I fixed that for you...  smiley-cool
