Loading...
Pages: [1]   Go Down
Author Topic: MOSFETs after h-bridge chip?  (Read 349 times)
Offline Offline
Jr. Member
View Profile
Is it generally acceptable to place MOSFETs after an h bridge to control a motor requiring high current using PWM?  In this case around 6A @ 12VDC.  If not is there a better way to do it?
Logged
South Texas
Offline Offline
God Member
View Profile
No = you need a bigger H-Bridge. Do a little research into how an H-Bridge works and you will understand.
Logged
Offline Offline
Jr. Member
View Profile
I understand how they work I just wondered if it was acceptable to add mosfets to the output of something like an L293D so it would handle higher current.  It sounds like you are saying to build my own h bridge out of mosfets and skip the L293D?
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
So you're talking something like this, where the L293D is used to drive the Gates of standard MOSFETs from 0 to +12V say (need more than 10V for full on).
I don't see why it couldn't be used as a MOSFET driver.
L239D has diodes built in, you'd want to add those here with the external MOSFETs if controlling a motor.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Offline Offline
Jr. Member
View Profile
Yes that's what I was talking about. If that is outside the norm I can make the h bridge if that is what most would do.
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
A lot depends on the voltage you use.  You are talking high power, which usually means higher voltage, so you need some kind of buffer in front of the PNPs anyway to let them swing up to 12V (in this example), can use single transistor with pullup resistor, or use the L293 for that.
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
You would get better performance from a purpose-designed MOSFET driver of course (much faster switching speed
for instance), and the L293D probably won't fully turn-off most MOSFETs due to the 1V or so drop across the darlington
output stage (but it'll probably turn off enough to be workable).  A H-bridge made from MOSFETs doesn't need diodes
BTW, power MOSFETs have built-in body diodes.
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Quote
You probably need to buy an h-bridge off of ebay instead of DIY.
Logged
Why I like my 2005 rio yellow Honda S2000 with the top down, and more!
GOOGLE ADVANCED FORUM SEARCH BELOW!
Go to:  http://www.google.com/advanced_search?hl=en
put in key search words,
use site or domain:  http://arduino.cc/forum
or in a google search box put key words site:http://arduino.cc/forum
Pages: [1]   Go Up
Print
Jump to:
