Loading...
Pages: [1] 2   Go Down
Author Topic: 30 pin 4 digit display  (Read 1150 times)
Offline Offline
Newbie
View Profile
HI I am using a 30-pin 4 digit display i ripped out of an alarm clock. With luck I found that someone had done the same thing with the same model number and made this schematic:
From my understanding, for most segments, you activate one of the two grounds on the circuit (pin 1 or pin 2) to select one of two segments. I confirmed that this works..you can see in this video here: ( )
I set up my arduino like so:
Arduino pins 2,3,4,5,6,7 - (handling pins 16-21 from display)
Arduino pins 8, 9, 10 - 74HC595 8 bit shift register (handling 5,6,9,10,12,13,14,15 pins from display)
Arduino pin 11   - Two center dots (pin 30 from display)
Arduino pin 12, 13 - ground 1 (pin 1) + ground 2 (pin 2)
My issue is how to program it....because to print numbers,  you will always need ground 1  for a segment on pin x but ground 2 for a segment on pin y at the same time.
I attempted to use delay(5) in between pinMode changes of the ground ...but this is not perfect as it doesnt really work with the shift register, and doesnt seem like it would be the properly ..
 Anyone have any clue, I am a newbie! thanks so much!
-chris
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Quote
You do not need to change the pin mode.
You do need resistors in line with the LEDs.
You need to multiplex the display, that is display some segments for a short time and then swap over and display the others. Done rapidly enough it will look like they are on all the time.
Logged
Valencia, Spain
Offline Offline
Edison Member
View Profile
You alternate quickly between the two sets of LEDs. Persistence of vision does the rest.
The word "multiplexing" in the name of the forum...? That's what this technique is called.
Logged
Offline Offline
Newbie
View Profile
Yes but in the scheme, 2 segments LEDs are controlled by 1 pin and the ground is what can change.. Is this not right? How can I alternate 2 LEDs from that one pin?
Logged
Offline Offline
Brattain Member
View Profile
WWW
Yes it is right.
It is simple, you set the anode high and the cathode low to light only one segment. If the other cathode is set low then you do not set the anode high if you do not want the segment on.
Logged
Valencia, Spain
Offline Offline
Edison Member
View Profile
The input voltage isn't fixed. It has to change to match the LED that's connected to ground.
Logged
Offline Offline
Newbie
View Profile
Ok thanks I think this works with the LEDs connected to pins directly, but for some reason it doesn't work properly with the shift register LEDs , I think it has something to do with the 2 gnds and 2 vccs connected to it...which when setting a segment on.. it either enables 2 segments or none..any ideas? Thanks guys!
Logged
Offline Offline
Edison Member
View Profile
The design is fairly unique. I wonder if there are very clever way of driving it.
Logged
Offline Offline
Newbie
View Profile
ok guys, i managed to fix my problems with the register, and im slowly building a driving function...but with all the delays when switching voltages...the display is not super bright and now noticeably flickery...im using delay(5) in between voltage changes and display clears. Longer delay causes flickeryness, shorter causes dimness...
here is my code...any solutions? so closeeeeee!!
Code:
//shows the 4 digits on screen
void show_num(int a,int b,int c,int d){
  //turn on dots
      clearSegments();
       swapGround(ground1);
       digitalWrite(dotsPin, HIGH);
       delay(5);
    switch (a){
    case 1:
      clearSegments();
      swapGround(ground2);
      setRegisterPin(5, HIGH); //with g2,
      setRegisterPin(6, HIGH);
      writeRegisters();
       delay(5);
  switch (b){
    case 1:
      clearSegments();
      setRegisterPin(3, HIGH); //with g2,
      setRegisterPin(4, HIGH);
      writeRegisters();
       delay(5);
    case 2:
      clearSegments();
      //bottom right
      setRegisterPin(4, HIGH); //with g2
      writeRegisters();
       delay(5);
      clearSegments();
      //bottom right
      setRegisterPin(2, HIGH); //with g2
      writeRegisters();
       delay(5);
  switch (c){
    case 1:
      clearSegments();
      digitalWrite(ledPins[2], HIGH);
      setRegisterPin(0, HIGH);
      writeRegisters();
       delay(5);
  switch (d){
    case 1:
    clearSegments();
    digitalWrite(ledPins[5], HIGH);
    delay(5);
void loop(){
 show_num(1,2,1,1);
Function descriptions:
clearSegments() - resets all pins to low
swapGround() - switches the voltages
clearRegisters() - resets registered pins to low
setRegisterPin() -  set a register pin to high or low
writeRegisters() - update display with updated register
Code:
void clearSegments(){
//turn off normal pin leds
for (int x=0; x<ledLength; x++){
      digitalWrite(ledPins[x], LOW);
      digitalWrite(dotsPin, LOW);
      clearRegisters();
      writeRegisters();
void swapGround(int gr){
      if (gr==ground1){
        //  Serial.println("switched to ground 1");
         digitalWrite(ground1, LOW);
         digitalWrite(ground2, HIGH);
      else if (gr==ground2){
         //Serial.println("switched to ground 2");
         digitalWrite(ground2, LOW);
         digitalWrite(ground1, HIGH);
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Without reading your code in great length, I suggest a fairly short delay for the "on state" and a very short or no delay for the clear.
So you want the segments to be on, more than they are off.
Logged
Offline Offline
Newbie
View Profile
i have a "delay(5)" for display and no delay for the  clear...if i decrease it any further...the display is not on long enough and it gets even dimmer. if I increase it to say delay( 8 )...it becomes way too flickery.
« Last Edit: December 29, 2012, 08:25:05 pm by cjm771 » Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Can you post all of the current code please, so we can see exactly the context of what you are doing where?
Logged
Offline Offline
Newbie
View Profile
below is my full code...i posted some explanation in a few posts previous to this in regards to some of the functions
basically for each digit, (except 1 and 7), it has to switch the high and low twice...with a delay(5) of between switches for displaying. this is done in "show_num"
show_num(a,b,c,d) - shows digits specified in args
Code:
//How many of the shift registers - change this
#define number_of_74hc595s 1
//do not touch
#define numOfRegisterPins number_of_74hc595s * 8
boolean registers[numOfRegisterPins];
int const ledLength = 6;
int ledPins[ledLength] = {2,3,4,5,6,7};
int dotsPin =  11;
int SER_Pin = 8;   //pin 14 on the 75HC595
int RCLK_Pin = 9;  //pin 12 on the 75HC595
int SRCLK_Pin = 10; //pin 11 on the 75HC595
int ground1 = 12;
int ground2 = 13;
void setup(){
          pinMode(ledPins[x], OUTPUT);
       // Serial.begin(9600);
        pinMode(dotsPin, OUTPUT);
        pinMode(SER_Pin, OUTPUT);
        pinMode(ground1, OUTPUT);
        pinMode(ground2, OUTPUT);
        pinMode(RCLK_Pin, OUTPUT);
        pinMode(SRCLK_Pin, OUTPUT);
          //reset all register pins
       clearRegisters();
         writeRegisters();
  //turn on dots
      clearSegments();
       delay(5);
    switch (a){
    case 1:
      clearSegments();
      writeRegisters();
       delay(5);
  switch (b){
   case 0:
    clearSegments();
    //bottom right
    //setRegisterPin(4, HIGH); //with g2
    writeRegisters();
     delay(5);
    clearSegments();
    //bottom right
    writeRegisters();
       delay(5);
    case 1:
      clearSegments();
      writeRegisters();
       delay(5);
    case 2:
      clearSegments();
      //bottom right
      writeRegisters();
       delay(5);
      clearSegments();
      //bottom right
      writeRegisters();
       delay(5);
    case 3:
      clearSegments();
      //bottom right
      writeRegisters();
       delay(5);
      clearSegments();
      //bottom right
      writeRegisters();
       delay(5);
    case 4:
      clearSegments();
      //bottom right
      writeRegisters();
       delay(5);
      clearSegments();
      //bottom right
      writeRegisters();
       delay(5);
   case 5:
      clearSegments();
      //bottom right
      writeRegisters();
       delay(5);
      clearSegments();
      //bottom right
      writeRegisters();
       delay(5);
     case 6:
      clearSegments();
      //bottom right
      writeRegisters();
       delay(5);
      clearSegments();
      //bottom right
      writeRegisters();
       delay(5);
   case 7:
      clearSegments();
      //bottom right
      writeRegisters();
       delay(5);
    case 8:
      clearSegments();
      //bottom right
      writeRegisters();
       delay(5);
      clearSegments();
      //bottom right
      //setRegisterPin(5, HIGH); //with g2
      writeRegisters();
       delay(5);
    case 9:
      clearSegments();
      //bottom right
      writeRegisters();
       delay(5);
      clearSegments();
      //bottom right
      writeRegisters();
       delay(5);
  switch (c){
    case 1:
      clearSegments();
      writeRegisters();
       delay(5);
  switch (d){
    case 1:
    clearSegments();
    delay(5);
int x_=0;
int start = millis();
void loop(){
 //loop numbers
   x_= int(millis()/1000)%10;
   show_num(0,x_,1,1);
show_num(1,7,1,1);
//set all register pins to LOW
void clearRegisters(){
  for(int i = numOfRegisterPins - 1; i >=  0; i--){
     registers[i] = LOW;
      clearRegisters();
      writeRegisters();
      if (gr==ground1){
//Set and display registers
//Only call AFTER all values are set how you would like (slow otherwise)
void writeRegisters(){
  digitalWrite(RCLK_Pin, LOW);
    digitalWrite(SRCLK_Pin, LOW);
    int val = registers[i];
    digitalWrite(SER_Pin, val);
    digitalWrite(SRCLK_Pin, HIGH);
  digitalWrite(RCLK_Pin, HIGH);
//set an individual pin HIGH or LOW
void setRegisterPin(int index, int value){
  registers[index] = value;
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
What is the purpose of this first delay?
Code:
  //turn on dots
  clearSegments();
  delay(5);    // <---------------- this one
Also I suggest you change all that delay(5) to delay(delayTime) where delayTime is a constant. That will make it much easier to tweak the delays.
Code:
const byte delayTime = 5;
Logged
Offline Offline
Newbie
View Profile
thats for the 2 dots, in the middle.. they will always be displayed. and true that about the constant, ive been meaning to do so.
Logged
Pages: [1] 2   Go Up
Print
Jump to:
