Loading...
Pages: [1]   Go Down
Author Topic: what I'm missing here  (Read 311 times)
Portugal
Offline Offline
God Member
Tomorrow I will know a BIT more than yesterday
View Profile
Hello folks
I'm trying to build a RS485 library and I'm testint it now.I'm using Visual Basic to inject some packets on the RS485 BUS and debug the outuput using a Saleae Logic Analiser.
I only have one function on the main loop for now but I should expect to see the answer from the microcontroller when is ID is called on the BUS right after he received the message and then answer back.It works most of the time but looking on the Saleae Software sometimes he ignores some stream packects and don't give the answer.For now I just have one slave on the BUS.
Here is the output from the software.
Channel 0 is connect to the RX atmega328 pin and the channel 1 is connect to TX Pin.Channel 3 is connect to the Pin 2 and 3 from the MAX485(when is low is on receive mode, when is High on seend Mode)
I don´t figure out why is a gap in some answer as I can see on the image
Also here is my code and the library in working on
Code:
#include "RS485.h"
RS485 bus;
bus.begin(2,3); //Device address and hardware pin connected to MAX485 enable Pins 2 and 3
bus.rxMode();      //Set de Bus on receive mode
bus.listen();
Logged
Debian,Mint,Ubuntu
Arduino Mega 2560
Arduino Nano
Arduino Duemilanove
MAC OS Montain Lion
Raspberry PI Model B
Global Moderator
Melbourne, Australia
Online Online
Shannon Member
Lua rocks!
View Profile
WWW
Code:
RS485::RS485(){}
If you constructor isn't going to do anything you can omit it.
Code:
//________________________________________________
void RS485::listen()
  if(Serial.read() ==  startByte)//Probe if first byte is the start Byte
    //Serial.println("Recebido StartByte");
    while(Serial.available()<=6);//Waits for the remaining 7 bytes
    if(Serial.read() == slaveID)//Check the Slave ID
     dataReceived[0] = startByte;
     dataReceived[1] = slaveID;
     for (uint8_t i = 0; i<= 5; i++) dataReceived[i+2] = Serial.read();
     byte tempCRC = dataReceived[7];
     dataReceived[7] = tempCRC;
     if(verify_checkSum(tempCRC,dataReceived))functionTable(dataReceived);//Go to the Function Table
   else while(Serial.read() != -1);
I don't like this for a number of reasons. If you don't get a startByte you then keep reading until you get nothing. What if the startByte is the second byte? You have now skipped it. What if two packets come in quick succession, but there is noise in the very first byte? You have now skipped two packets. Also I prefer to test for if Serial.available rather than checking if you get -1 back.
I recently did a non-blocking RS485 library here:
http://www.gammon.com.au/forum/?id=11428
In that I use a "state machine" where you transition from "no packet" to "filling the packet" to "calculate the CRC". That code will work even if the bytes come at odd intervals.
Logged
Wellington, New Zealand
Offline Offline
Newbie
View Profile
WWW
Hi Nick,
I found the above page you wrote about a week ago and its one of the best descriptions of implementing RS485 that I could find online.
Just want to thank you for the effort you have put into it, It is inspirational.
« Last Edit: December 30, 2012, 02:12:45 am by Protoneer » Logged
Global Moderator
Online Online
Shannon Member
Lua rocks!
View Profile
WWW
Glad you like it, and thanks for the complimentary remarks. smiley
Logged
Pages: [1]   Go Up
Print
Jump to:
