North Queensland, Australia
Offline
Edison Member
« on: December 29, 2012, 06:19:34 am » |
Hi all, I have a need for a serial monitor with a binary dump feature, not a technological poo, but a 'save raw data to file' feature. The only decent app I found so far is 'advanced serial port monitor' but its not free and my trial expired.
All I need is to save a TFT screenshot to the computer ( bitmap header is sent in data ). Or maybe someone knows of an app that can receive image data via serial?
Cheers chris.
Logged
Netherlands
Online
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
« Reply #1 on: December 29, 2012, 06:21:53 am » |
I often use putty.exe for this
Logged
Offline
Edison Member
« Reply #2 on: December 29, 2012, 09:09:38 am » |
I gave putty a try, but I cannot see how to save the output as raw binary, the saved log file is larger than the amount of data sent. Any hints.
Logged
Netherlands
Online
Tesla Member
« Reply #3 on: December 29, 2012, 09:19:35 am » |
try under logging -> all session output void setup() { Serial.begin(9600); for (int i=0; i<255;i++) { Serial.write(i); } }
void loop(){}
viewing with a hexviewer gives output as expected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he 0D is a return - interpreted by the viewer
« Last Edit: December 29, 2012, 09:30:01 am by robtillaart »
Logged
Chile
Offline
Edison Member
Arduino rocks
« Reply #4 on: December 29, 2012, 10:32:14 am » |
HTERM rocks! it is free and very powerful
Logged
Offline
Edison Member
« Reply #5 on: December 30, 2012, 11:57:27 am » |
You are right! It was exactly what I needed, I tried maybe 8 different serial apps... All pretty much useless, well not useful for my needs. HTerm was so straight forward, option for raw save and 2 clicks for capture. Finally got some screen captures happening. Thank you. Thanks robtillaart too, your input is appreciated.
Logged
Greenville, IL
Offline
Edison Member
Warning Novice on board! 0 to 1 chance of errors!
« Reply #6 on: December 31, 2012, 08:49:07 pm » |
Any recommendation where to download the app. from? Preferably an English site. I found a few places using a search but, I was worried about getting added crap with it.
Logged
Chile
Offline
Edison Member
Arduino rocks
« Reply #7 on: December 31, 2012, 09:29:43 pm » |
Logged
Offline
Newbie
« Reply #8 on: December 31, 2012, 10:18:45 pm » |
What about Terminal v1.9b also free I especially like the macro buttons & although I've not tried has inbuilt graphing capability https://sites.google.com/site/terminalbpp/ should get you there... Happy NY
Logged
Greenville, IL
Offline
Edison Member
« Reply #9 on: January 01, 2013, 07:35:08 am » |
Thank you! I looked the program over and I like it! I will have to test it later and try out the features.
Logged
Left Coast, CA (USA)
Offline
Brattain Member
Measurement changes behavior
« Reply #10 on: January 01, 2013, 09:45:59 am » |
That is the so called brey terminal and is a wonderful troubleshooting tool, I''ve been using it for years. I see I'm a rev behind and will have to check out the latest version. Lefty
Logged
Offline
Newbie
« Reply #11 on: January 01, 2013, 12:34:15 pm » |
Here http://hobby-roboter.de/forum/viewtopic.php?f=4&t=139 I've written a python program for displaying and logging data from the arduino. To write data to a file from Arduino is quite simple: Serial.print("w2file "); Serial.println(sensorValue); // write value to file A demo program for logging analog values would be as follows: int sensorValue = 0; // value read from the pot
void setup() { // initialize serial communications at 9600 bps: Serial.begin(9600); }
//Serial.println("cls"); // clear screen Serial.println("pos 0 460"); // set cursor position to 0,460 Serial.println("print write analog values to file"); Serial.println("pos 100 300"); // set cursor position to 0,460 sensorValue = analogRead(A0); Serial.print("print "); Serial.println(sensorValue); // print value on screen Serial.print("w2file "); Serial.println(sensorValue); // write value to file delay(2000); }
« Last Edit: January 01, 2013, 03:59:45 pm by ChrisMicro »
Logged
Global Moderator
Dallas
Offline
Shannon Member
« Reply #12 on: January 01, 2013, 03:00:55 pm » |
What about Terminal v1.9b also free It (still) has a nasty buffer corruption bug. For most uses the bug falls somewhere between irrelevant and minor inconvenience. For logging binary data the bug is a show-stopper. Even with the bug, it's the terminal application I turn to first. Lately I've been using Python for "advanced" applications (like logging binary data).
Logged
Beijing
Offline
Full Member
Skype name habib.derbyshire
« Reply #13 on: January 03, 2013, 06:13:17 am » |
Coolterm can record the serial info and save it.
Logged
What is man's best friend? The breadboard!
Chile
Offline
Edison Member
Arduino rocks
« Reply #14 on: January 03, 2013, 07:12:32 am » |
HTERM kicks all other serial monitor virtual asses  I ve tested them all
Logged
