Topic: ATtiny2313 with arduino-tiny core libs 0100-0015: compile errors (Read 4050 times) previous topic - next topic
AgeBee
I get compile errors when trying to build a simple sketch for the ATtiny2313 with the core libs which I downloaded from here:
http://code.google.com/p/arduino-tiny/downloads/detail?name=arduino-tiny-0100-0015.zip
The error reads:
In file included from /usr/lib/gcc/avr/4.7.0/../../../avr/include/util/delay.h:44:0,
                 from /usr/lib/gcc/avr/4.7.0/../../../avr/include/avr/delay.h:37,
                 from /usr/share/arduino/hardware/tiny/cores/tiny/wiring_private.h:32,
                 from /usr/share/arduino/hardware/tiny/cores/tiny/WInterrupts.c:37:
/usr/lib/gcc/avr/4.7.0/../../../avr/include/math.h:427:15: error: expected identifier or '(' before 'double'
/usr/lib/gcc/avr/4.7.0/../../../avr/include/math.h:427:15: error: expected ')' before '>=' token
I followed several suggestions uncommenting the line in math.h (http://code.google.com/p/arduino-tiny/issues/detail?id=29):
#define round(x)     ((x)>=0?(long)((x)+0.5):(long)((x)-0.5))
That did not help me either because that produces another error:
/usr/share/arduino/hardware/tiny/cores/tiny/HardwareSerial.cpp:94:15: error: attempt to use poisoned "SIG_USART0_RECV"
I compile against avr 4.7.0 with Arduino 1.0.1 on Ubuntu 12.10.
Maybe it's the gcc-avr version which produces the error ?
Did anybody solve the problem with the above mentioned libs under Arduino 1.0.1 ?
Regards
AgeBee
Coding Badly
Does this help...
http://code.google.com/p/arduino/issues/detail?id=955
AgeBee
Does this help...
Thanks for your instant reply.
I already came across this article which suggests downgrading the gcc-avr to 4.3.5.
The strange thing however is that my setup works for all other boards (controllers) like the ATtiny4313, ATtiny44, ATTiny25, ATtiny85 a.s.o.
The only one not working is the ATtiny2313. That prevented me from downgrading very quickly.
Coding Badly
No problem.  I will offer a potential solution but there is a condition.  You have to report back if the solution works (or doesn't).  Agreed?  Excellent, let's get started...
• Locate and open[font=Courier New] HardwareSerial.cpp [/font]in the [font=Courier New]{Sketch}/hardware/tiny/cores/tiny directory/[/font]
• Replace all occurrences of[font=Courier New] SIGNAL [/font]with[font=Courier New] ISR[/font]
• Save and close[font=Courier New] HardwareSerial.cpp[/font]
• Try to compile
AgeBee
• Try to compile
Thanks a bunch for your quick help. Sure I will and I did as you wanted but without success:
In HardwareSerial.cpp line 94 reads this:
#elif defined(SIG_USART0_RECV) && defined(UDR0)
Coding Badly
Huh.  That thing is a righteous mess isn't it.
This is what I did...
• Replace[font=Courier New] SIG_USART0_RECV [/font]with[font=Courier New] USART0_RECV_vect[/font]
• Replace[font=Courier New] SIG_UART0_RECV [/font]with[font=Courier New] UART0_RECV_vect[/font]
• Replace[font=Courier New] SIG_UART_RECV [/font]with[font=Courier New] UART_RECV_vect[/font]
• Delete the following starting at line #167...
[font=Courier New]#elif defined(SIG_USART3_RECV)
  #error SIG_USART3_RECV[/font]
• Delete the following starting at line #157...
[font=Courier New]#elif defined(SIG_USART2_RECV)
  #error SIG_USART2_RECV[/font]
• Delete the following starting at line #147...
[font=Courier New]#elif defined(SIG_USART1_RECV)
  #error SIG_USART1_RECV[/font]
Attached to this post is the updated HardwareSerial.cpp.  Locate the version on your computer and replace it with the one attached.  Same condition as before: please let me know what happens.
AgeBee
Hi Coding Badly,
that worked like charm ! Thank you very much for your help.
If this forum would have the status 'holy' for the members it would be definitely you who deserves it first.
Wishing you a pleasant and sound new year.
Harald
Coding Badly
Excellent.  Thank you for letting me know.
You are welcome.
Back at ya!
