Loading...
Pages: [1]   Go Down
Author Topic: Arduino Question  (Read 178 times)
Offline Offline
Newbie
View Profile
Is the Arduino computer software only allow you to program any of the robot kits or can you make it remote control?
Logged
Offline Offline
Newbie
View Profile
it would be helpful if you can rephrase your question   smiley
Logged
Central MN, USA
Offline Offline
Faraday Member
Phi_prompt, phi_interfaces, phi-2 shields, phi-panels
View Profile
WWW
Arduino software is not associated with robot kits as far as I know. You are probably learning about arduino through a robot kit that uses arduino environment. Arduino is a physical computing platform and there are lots of ways to wirelessly operate arduino but I don't know about YOUR robot kit. Which robot kit?
Logged
Offline Offline
Newbie
View Profile
I don't have a kit yet. I'm asking if it is a programmable robot like the LEGO Mindstorms (where the actions of the robot are predetermined), or can it be controlled directly using a control. I'm not getting a kit until a find out everything about it. Also, is the MAKE Rovera 2WD or 4WD Arduino Robot Kit contolled by the Arduino program. Sorry, I'm new and confused. I was interested in EZ-Robot, but I just want to find the similarities between it and this. Sorry if this is confusing  smiley-confuse
Logged
Central MN, USA
Offline Offline
Faraday Member
View Profile
WWW
LEGO mindstorm compares with Arduino-compatible robots is LEGO pieces compared with 3D printer. You have very limited capability building things with LEGO pieces. You can pretty much print any shape with a 3D printer. But, with the freedom comes with the responsibility. You will need to write some code for the robot, although there are many codes available. Point here, arduino is not a toy. It is a tool.
Logged
Vlissingen Netherlands
Offline Offline
Newbie
View Profile
Arduino is much more capable of doing things then the lego mindstorms.
So if you want to program a robot arduino can do the job very well, but it depends also on yourself, i mean you need to do a lot of reading and experimenting to get familiar with the whole concept.
And shure there are extensions which you can use to operate your system, but that needs to be programmed as well.
I suggest you find a board and do some experiments first to start building a robot, or buy a robot thats build on a arduino controller.
I myself have a aar-04 from Arexx.com the cell them at Conrad in NL,DE and UK, it works fine for me to get familiar with the code and functions you can choose and use.
« Last Edit: December 30, 2012, 07:30:35 am by FreakyDuino » Logged
Poole, Dorset, UK
Offline Offline
God Member
View Profile
The Lego system has its own IDE.
Mark
Logged
Pages: [1]   Go Up
Print
Jump to:
