Topic: Do not follow Simple Audio Player example - DAC0 now non-functional on DUE (Read 24815 times) previous topic - next topic
jknighton
Just to let everyone know - do not follow the Arduino Due Simple Audio Player example and connect a speaker direct to DAC0 without resistors.  My DAC is now damaged.
Is there anyway to get a replacement?  I know it is normally experimenter beware, but I was just following directions in the official IDE...
JacekPintera
decrux
I once read that the Due DAC's highest voltage is about 2.55 V, with 8 Ohm I get about 318 mA. Isn't that already too high for the uC?
Possible options: 318 mA are no problem or it isn't 8 Ohm because the impedance depends on the frequency.
Another related question: If 8 Ohm Speakers work without a resistor, is it then possible to use 4 Ohm Speakers and simply add a 4 Ohm resistor? I'm hoping for appropriate help :)
Greetings
decrux
Arctic_Eddie
You need an audio amplifier chip between the Due and the speaker. There are many but the LM380 or LM383 would work nicely.
Grumpy_Mike
Yes it is.
True but the impedance is still too low for the pin.
No.
The current limit on a Due is about 15mA so a 220R resistor is about as small as you can go. At that there will be so little current trough the speaker I doubt if you can hear anything. I would recommend a headphone ear piece, a 1uF capacitor and a 470R resistor all in series. Or an external amplifier.
Massimo Banzi
That tutorial is clearly wrong and I am sorry it slipped past the QA process..
It's being removed now.
jknighton please write to support (at) arduino.cc explaining the situation and you'll get a new board
I'm sorry for the inconvenient
m
raalst
for what it's worth, I have had good success creating sound using a *powered* PC speakerset.
just find the (green) plug of the speakerset and connect ground and a channel to the gnd and dac pin respectively.
DuaneB
My DAC0 has also just died, in my case the Arduino was connected to an LM386 amp. I cannot find any problems with the amp, I am posting in case others have similar experiences.
Can I also suggest that any future DAC related tutorials include a series current limiting resistor - I was not using one, but if the issue was one my side it might have same my DAC0.
Duane B
rcarduino.blogspot.com
Read this
http://rcarduino.blogspot.com/2012/04/servo-problems-with-arduino-part-1.html
then watch this
http://rcarduino.blogspot.com/2012/04/servo-problems-part-2-demonstration.html
Rcarduino.blogspot.com
Arctic_Eddie
The LMxxx amps have an input bias voltage. If the impedance of this voltage source is low enough, it could feed back into the DAC and damage it's output driver. I've measured the LM383 and find 0.6V. There should be at least a series coupling capacitor. Also, a current limiting resistor would certainly be appropriate for testing purposes.
raalst
if the DAC seems to have given up the ghost,
could you please try this simple test sketch ?
I was messing with the Simple Audio Player too, and did not get any signal from the dac. might have been me,
but just maybe there is a problem in the simple audio player code, instead of a hardware failure..
this sketch outputs a ramp on both dac channels forever. if you have no oscilloscope, you should see a non-zero voltage (i measured about 2.3 volts) on a multimeter.
Serial.begin(19200);
Serial.println("program start");
 for (int i = 0; i <256; i++) analogWrite(DAC0,i);
 for (int j = 0; j <256; j++) analogWrite(DAC1,j);
Palliser
The very first sketch I ran in my DUE was the "Simple Audio Player" and it worked great with a Seeed SD card shield and a 16 ohm RadioShack speaker (made in China). I haven't tried again since then. May be I was lucky.
stimmer
My DAC0 doesn't work either. I don't think I've ever had it connected to anything though (until now, obviously!) It's one of the early boards where DAC0 is marked as "DAC2", and I've only ever used DAC1, which works fine. Very strange :~
Due VGA library - http://arduino.cc/forum/index.php/topic,150517.0.html
DuaneB
   I was using my own DDS Code - http://rcarduino.blogspot.com/2012/12/arduino-due-dds-part-1-sinewaves-and.html - against an LM386 circuit which I have used extensively on UNO's and Mega's. DAC0 is dead, as a quick test I tried DAC1 and its still working, I do not want to use it though until I know why DAC0 has failed.
My board has the DAC outputs labelled DAC1 and DAC0 .
Duane B
Read this
then watch this
floris497
hi,
my DAC0 also died :( but DAC1 is still working.. why is it the DAC0 only dies and not the DAC1??
is that a hardware failure? or something else?
and what do do now? van this be fixed somehow?
Floris
DuaneB
DAC0 is the one you learn on, DAC1 is the one you then take care of.
Duane B
Read this
then watch this
