Topic: Library for playing MIDI files from the Arduino (Read 18314 times) previous topic - next topic
robtillaart
Welcome!
(nitpick?)
some one who keeps nagging about details - I don't know for sure if nitpicking is the right term here (English is not my mother tongue)
Think there will be a point release soon ;)
I have renamed it 'h'
much better ;)
Rob Tillaart
marco_c
I do appreciate your time in reviewing. When I used to write software for a living it was amazing how much better code could be when a fresh set of eyes were applied and constructive comments passed.
Yes, there will be a pint release once I can check a few things.
Arduino Libraries https://github.com/MajicDesigns?tab=Repositories
Parola for Arduino https://github.com/MajicDesigns/Parola
robtillaart
I like that ;)
Rob Tillaart
jon_s
Thanks for your work on this -- I can see a lot of applications and think it will be helpful for a lot of people.
I have a related newbie question: For those of us without an SD-enabled Ethernet shield, what adjustments should be made? I have an adafruit waveshield and will be getting an SD breakout shield, but I'm not sure what modifications in SD reading pins to make. For instance, your MIDIFile_Play sample uses "#define SD_SELECT 4"; it might be helpful to explain what an "SD chip select pin" is and what other common values might be for other arduino versions or shields with SD readers.
Also, I imagine it would be possible to store very small MIDI files in the arduino's memory itself. That would open up some options for people who want to play back simple music or other actions (lights, servos, etc.) with an open, easy-to-modify standard like MIDI, but without needing to include an SD card in their setup. Would that be hard to do? What would be the best way to approach that?
Thanks again. Looking forward to learning enough to use this.
robtillaart
Start building it.
Rob Tillaart
marco_c
I like that
Sometimes typos probably reflect the truth ...
Pint release is on the download site.
marco_c
#21
Jan 06, 2013, 11:36 pm Last Edit: Jan 06, 2013, 11:47 pm by marco_c Reason: 1
Depends on your hardware.
SD cards use the SPI pins on the Arduino to transfer data. This is a bus (ie, multiple devices can be connected to the same pins to send and receive data),  so a device needs to know when it needs to communicate. This is done by a SELECT line, and each SPI devices needs a separate select line. The SD_SELECT define is the pin to use to select the SD card in the SdFat library.
What you need to change it to depends on how your hardware is configured, and will be documented as part of you hardware. Common values are Arduino Ethernet shield pin 4, Sparkfun SD shield pin 8, Adafruit SD shields and modules pin 10. The main thing is that all of these devices need to coexist and not use the same pin or we can't select the device independently of the others. This pin also can't be used for anything else in the program.
They would be very small indeed, as the files would need to be stored in RAM for them to be edited, which on my Uno is very small. This is not the same as the program storage memory, by the way, which is reported by the IDE when you compile your programs.
Not especially. However, if you have a program that always plays the same music, then the music is hard coded in the software that you write. At that point you are not interpreting a MIDI file, but just sending out MIDI commands through the serial port - you don't need the overhead of a library like this one.
SD card readers are not that expensive. I got one recently from eBay for less than $1.50 (http://www.ebay.com.au/itm/280780639068?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649) that could be used as-is in a breadboard setup. I chose to mount it permanently onto a prototyping shield and put in a jumper so that I could change the select line anywhere between pins 2 and 10 so that I am less likely to clash with other cards. All up probably cost $5.
marco_c
New version 1.2 of the library has been loaded to my repository (see signature).
v1.2 has examples cleaned up and better commented. The dependency on the MIDI library has been removed . There are no dignificant changes to the core library.
scriptstyle
I am running arduino 1.0.5, I have the appropriate libraries Midi, Data flash, midifile, Sdfat... I plan on running MIDIFile_Play_LCD on a uno SDsheild and 2x16 LCD. So far just setting up libraries and waiting on a mouser order. I am a bit new to micros but not to electronics, and this is my 2nd arduino project...
Problem is when i compile the sketch i get this error
'A0' was not declared in this scope
In file included from MIDIFile_Play_LCD.ino:14:
KeyPress.h: In function 'char getLCDKey()':
KeyPress.h:32: error: 'A0' was not declared in this scope
KeyPress.h:32: error: 'analogRead' was not declared in this scope
KeyPress.h:35: error: 'millis' was not declared in this scope
MIDIFile_Play_LCD.ino: At global scope:
MIDIFile_Play_LCD:47: error: variable or field 'midiCallback' declared void
MIDIFile_Play_LCD:47: error: 'midi_event' was not declared in this scope
MIDIFile_Play_LCD:47: error: 'pev' was not declared in this scope
MIDIFile_Play_LCD:48: error: variable or field 'sysexCallback' declared void
MIDIFile_Play_LCD:48: error: 'sysex_event' was not declared in this scope
MIDIFile_Play_LCD:48: error: 'pev' was not declared in this scope
MIDIFile_Play_LCD:69: error: 'SdFat' does not name a type
MIDIFile_Play_LCD:70: error: 'MIDIFile' does not name a type
MIDIFile_Play_LCD:79: error: variable or field 'midiCallback' declared void
MIDIFile_Play_LCD:79: error: 'midi_event' was not declared in this scope
MIDIFile_Play_LCD:79: error: 'pev' was not declared in this scope
i am guessing it has something to do with my libraries? Any help would be appreciated  :)
marco_c
#24
Jan 21, 2014, 09:47 am Last Edit: Jan 21, 2014, 09:51 am by marco_c Reason: 1
A 'oh' or A 'zero'? Are you compiling a standard example?
I have just tried it on my system and it works ok with 1.0.5.
scriptstyle
thank you for the fast reply
that was 'A ZERO'
now i reloaded libraries and I get a long string of errors when I verify the sketch in the main MIDIFile_Play_LCD tab it reads
In file included from MIDIFile_Play_LCD.ino:11:
/Users/scriptstyle/Documents/Arduino/libraries/MIDIFile/MIDIFile.h:174: error: 'SdFat' has not been declared
/Users/scriptstyle/Documents/Arduino/libraries/MIDIFile/MIDIFile.h:259: error: ISO C++ forbids declaration of 'SdFat' with no type
/Users/scriptstyle/Documents/Arduino/libraries/MIDIFile/MIDIFile.h:259: error: expected ';' before '*' token
/Users/scriptstyle/Documents/Arduino/libraries/MIDIFile/MIDIFile.h:260: error: 'SdFile' does not name a type
MIDIFile_Play_LCD.ino: In function 'uint16_t createPlaylistFile()':
MIDIFile_Play_LCD:166: error: 'SdFile' was not declared in this scope
MIDIFile_Play_LCD:166: error: expected `;' before 'plFile'
MIDIFile_Play_LCD:167: error: expected `;' before 'mFile'
MIDIFile_Play_LCD:172: error: 'plFile' was not declared in this scope
MIDIFile_Play_LCD:172: error: 'O_CREAT' was not declared in this scope
MIDIFile_Play_LCD:172: error: 'O_WRITE' was not declared in this scope
MIDIFile_Play_LCD:176: error: 'mFile' was not declared in this scope
MIDIFile_Play_LCD:176: error: 'SD' was not declared in this scope
MIDIFile_Play_LCD:176: error: 'O_READ' was not declared in this scope
MIDIFile_Play_LCD:184: error: 'plFile' was not declared in this scope
MIDIFile_Play_LCD:192: error: 'plFile' was not declared in this scope
MIDIFile_Play_LCD.ino: In function 'seq_state lcdFSM(seq_state)':
MIDIFile_Play_LCD:205: error: 'SdFile' does not name a type
MIDIFile_Play_LCD:212: error: 'plFile' was not declared in this scope
MIDIFile_Play_LCD:214: error: 'O_READ' was not declared in this scope
MIDIFile_Play_LCD:221: error: 'plFile' was not declared in this scope
MIDIFile_Play_LCD.ino: In function 'void setup()':
MIDIFile_Play_LCD:371: error: 'SD' was not declared in this scope
MIDIFile_Play_LCD:376: error: 'SPI_FULL_SPEED' was not declared in this scope
i am just trying to compile/verify your original sketch so i can upload to the uno and move on from there...
scriptstyle
with the file MIDIFile.h in my library I get the SDfat does not name a type errors, but when i delete MIDIFile.h from the library it skips that error goes to the keypress tab and reads, 'AO' was not declared in scope. and that does read as A-oh sorry. What am i missing with these errors?
marco_c
I am not sure what is happening here. You may be better posting this in the general programming section of the forum as I don't think this is related to the library but more likely to the way your system is organised.
scriptstyle
ok so i made some progress i now have the sketch loading to my uno just fine.
I am using a SD shield from seeed studio. I am almost 100% sure this is working properly, I ran SD example cardinfo: wiring is correct & card is present, and then it goes on show midi files on the card in the serial monitor.
I am using a 2x16 LCD i followed this correction and seemed to get it displaying characters but dosnt, seem to give a menu
// LCD pin definitions ---------
// These need to be modified for the LCD hardware setup
#define  LCD_RS    8
#define  LCD_ENA   9
#define  LCD_D4    4
#define  LCD_D5    (LCD_D4+1)
#define  LCD_D6    (LCD_D4+2)
#define  LCD_D7    (LCD_D4+3)
D5-1
D6-2
D7-3
LCD reads like this, i dont think this is the menu readout???
scriptstyle
Also i used this schematic to wire up a keypad, are these values same as what is expected? input on A0
