Topic: Speed Sensor (Velocity Km/H) Using Ultrasonic Sensor (Ping) (Read 18770 times) previous topic - next topic
matt121187
Dec 30, 2012, 11:28 am Last Edit: Dec 30, 2012, 03:47 pm by matt121187 Reason: 1
hello everybody..
can someone help me on this problem?
i have arduino mega and ping ultrasonic sensor, but the coding is problem for me. hopefully someone can help me......  =(
AWOL
#1
Dec 30, 2012, 12:05 pm Last Edit: Dec 30, 2012, 12:10 pm by AWOL Reason: 1
What's the problem, and why are you SHOUTING?
1kmh-1 is 0.277ms-1
The Ping can take maybe 20 readings a second, out to a sensible range of what? Four metres?
Do some simple sums.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
matt121187
#2
Dec 30, 2012, 03:45 pm Last Edit: Dec 30, 2012, 03:47 pm by matt121187 Reason: 1
can u help me for the coding part?i really blur to do the speed sensor coding...
AWOL
Can you stop and think for a moment, and tell us exactly what you're trying to do?
Also think about the limitations I described in my other post.
retrolefty
Your ping sensor is a simple time of flight sensor where the variable time represents the variable distance to a fixed object. To turn that into a speed sensor would require that you sense the change of distance of a return pulse of a moving object over a specific time period, so it's a second order value that would be based on the integration of the primary time of flight measurement that the sensor provides you. So the solution is math based.
Lefty
matt121187
sorry..
i try to do the speed sensor between two car to find the crash impact..
for the example..i put ping ultrasonic sensor in front of my car..than, find the different speed between my car and the front car..
AWOL
Quote
"If you can see my Ping, you're driving too close"   :)
OK, so show us your code so far.
JimboZA
Well assuming you have the coding done to measure the distance in the first place, which is well documented if I recall from looking at Ping)) some time ago....
In it's simplest form you just need to take two distance readings noting the time using millis() or micros() at which you took the readings. Then you calculate the speed as distance / time as:
Speed = (FirstDistance - SecondDistance) / (SecondTime - FirstTime)
If FirstDistance < SecondDistance the distance is increasing and the car in front is moving away; that would give a -ve speed.
Something like that, anyway  8)
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
matt121187
#8
Dec 30, 2012, 04:22 pm Last Edit: Dec 30, 2012, 04:35 pm by AWOL Reason: 1
Quote
yes..u are too close if u see my ping sensor..hehehe...
i dont know how to start the coding for speed sensor..before this i just 'play' with range..sens and show the range between your car, and front car..
Code: [Select]
#include <LiquidCrystal.h>   // lcd
LiquidCrystal lcd(12, 11, 5, 4, 3, 2); //lcd
const int pingPin = 7; //sensor
const int redPin = 6; //led
const int greenPin = 5; //led
const int bluePin = 4; //led
 // initialize serial communication:
 pinMode (redPin, OUTPUT);
 pinMode (greenPin, OUTPUT);
 pinMode (bluePin, OUTPUT);
 lcd.begin(16, 2);
 lcd.print("Distance (cm):");
 // establish variables for duration of the ping,
 // and the distance result in inches and centimeters:
 lcd.setCursor(0, 1);
 long duration, inches,cm;
 // The PING))) is triggered by a HIGH pulse of 2 or more microseconds.
 // Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
 pinMode(pingPin, OUTPUT);
 digitalWrite(pingPin, LOW);
 delayMicroseconds(2);
 digitalWrite(pingPin, HIGH);
 delayMicroseconds(15);
 delayMicroseconds(20);
 // The same pin is used to read the signal from the PING))): a HIGH
 // pulse whose duration is the time (in microseconds) from the sending
 // of the ping to the reception of its echo off of an object.
 pinMode(pingPin, INPUT);
 duration = pulseIn(pingPin, HIGH);
 inches = microsecondsToInches(duration);
 cm = microsecondsToCentimeters(duration);
 Serial.print(inches);
 Serial.print("in, ");
 Serial.print(cm);
 Serial.print("cm");
 // convert the time into a distance
 if (inches > 30) {
   digitalWrite(greenPin, HIGH);  // green LED
   digitalWrite(redPin, LOW);
   digitalWrite(bluePin, LOW);
 else if (inches <= 30 && inches > 12) {
   digitalWrite(redPin, HIGH);    // orange LED
 else if (inches <= 12 && inches > 6) {
   digitalWrite(redPin, LOW);    // red LED
   digitalWrite(bluePin, HIGH);
 else {
   digitalWrite(redPin, HIGH);    // purple LED
 lcd.print(cm);
 lcd.print("cm");
 lcd.print("");
 delay(100);
long microsecondsToInches(long microseconds)
 // According to Parallax's datasheet for the PING))), there are
 // 73.746 microseconds per inch (i.e. sound travels at 1130 feet per
 // second).  This gives the distance travelled by the ping, outbound
 // and return, so we divide by 2 to get the distance of the obstacle.
 // See: http://www.parallax.com/dl/docs/prod/acc/28015-PING-v1.3.pdf
 return microseconds / 74 / 2;
long microsecondsToCentimeters(long microseconds)
 // The speed of sound is 340 m/s or 29 microseconds per centimeter.
 // The ping travels out and back, so to find the distance of the
 // object we take half of the distance travelled.
 return microseconds / 29 / 2;
Moderator edit: CODE TAGS
matt121187
thank you for your idea.. if you can see from my code, where i can get the value of secondtime and first time?
AWOL
Quote
Here
JimboZA
Every time through loop() you are measuring the ping duration and then calculating a distance...
Where you read the duration, you could add a line like time = millis so that would record when in the day (or in fact since the sketch started running) that duration was captured.
You'll need to do something to move each current time reading into an oldtime variable (at the top of loop() ?) so that you can subtract one from the other to give the time between readings. Similarly, you'll need to move the current distance to an olddistance variable so you can subtract them.. as it stands now, values like cm and so on are overwritten each time through loop() so you need to have a means of storing the previous one before the new one comes along.
matt121187
JimboZA
okay friends..i will try first...
Awesome  8) .... and my advice is that before you dive into code, draw a flowchart of what it is you want to do. Get the logic clear on paper and in your head before you get into the nitty-gritties of coding.
matt121187
thanks for your advice..i just draw the flowchart..but i bit confusing to get the value of FirstDistance ,SecondDistance, SecondTime, FirstTime =(
