Pages: 1 [2]   Go Down
Author Topic: Speed Sensor (Velocity Km/H) Using Ultrasonic Sensor (Ping)  (Read 970 times)
i'm really blur...cant solve this problem.... smiley-cry
UK
In that case I suggest you pick a simpler problem.
Seattle, WA USA
Online Online
Seattle, WA USA
Can't or won't? What have you tried?
how to hold the previous distance?
this is my coding right now..but the previous state still show the current distance
const int pingPin = 7;
int start = 0;
  // initialize serial communication:
  // establish variables for duration of the ping,
  // and the distance result in inches and centimeters:
  long duration, inches, cm, currentState, previousState;
  // The PING))) is triggered by a HIGH pulse of 2 or more microseconds.
  // Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
  pinMode(pingPin, OUTPUT);
  digitalWrite(pingPin, LOW);
  delayMicroseconds(2);
  digitalWrite(pingPin, HIGH);
  delayMicroseconds(5);
  // The same pin is used to read the signal from the PING))): a HIGH
  // pulse whose duration is the time (in microseconds) from the sending
  // of the ping to the reception of its echo off of an object.
  pinMode(pingPin, INPUT);
  duration = pulseIn(pingPin, HIGH);
  // convert the time into a distance
  cm = microsecondsToCentimeters(duration);
  currentState = cm;
  previousState = currentState + start ;
  previousState = currentState;
  Serial.print(previousState);
  Serial.print("cm, ");
  Serial.print(currentState);
  Serial.print("cm");
  Serial.println();
  delay(100);
long microsecondsToCentimeters(long microseconds)
  // The speed of sound is 340 m/s or 29 microseconds per centimeter.
  // The ping travels out and back, so to find the distance of the
  // object we take half of the distance travelled.
  return microseconds / 29 / 2;
UK
Any variable declared within a function like "loop" is going to have limited use for remembering its value.
If you want a variable to maintain its value, declare it with global scope.
can u show me the example from my coding?
East Anglia (UK)
May all of your blinks be without delay
Left Coast, CA (USA)
Measurement changes behavior
I thought declaring a variable static solves any 'memory' problem for variables declared within the scope of a function?
Lefty
East Anglia (UK)
These variables aren't declared static in the routine though
UK
It does - I just suggested global scope because it is what most noobs are more comfortable with.
Pages: 1 [2]   Go Up
