Topic: Speed Sensor (Velocity Km/H) Using Ultrasonic Sensor (Ping) (Read 18797 times) previous topic - next topic
matt121187
PeterH
In that case I suggest you pick a simpler problem.
PaulS
cant solve this problem.
Can't or won't? What have you tried?
matt121187
how to hold the previous distance?
this is my coding right now..but the previous state still show the current distance
const int pingPin = 7;
int start = 0;
  // initialize serial communication:
  // establish variables for duration of the ping,
  // and the distance result in inches and centimeters:
  long duration, inches, cm, currentState, previousState;
  // The PING))) is triggered by a HIGH pulse of 2 or more microseconds.
  // Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
  pinMode(pingPin, OUTPUT);
  digitalWrite(pingPin, LOW);
  delayMicroseconds(2);
  digitalWrite(pingPin, HIGH);
  delayMicroseconds(5);
  // The same pin is used to read the signal from the PING))): a HIGH
  // pulse whose duration is the time (in microseconds) from the sending
  // of the ping to the reception of its echo off of an object.
  pinMode(pingPin, INPUT);
  duration = pulseIn(pingPin, HIGH);
  // convert the time into a distance
  cm = microsecondsToCentimeters(duration);
  currentState = cm;
  previousState = currentState + start ;
  previousState = currentState;
  Serial.print(previousState);
  Serial.print("cm, ");
  Serial.print(currentState);
  Serial.print("cm");
  Serial.println();
  delay(100);
long microsecondsToCentimeters(long microseconds)
  // The speed of sound is 340 m/s or 29 microseconds per centimeter.
  // The ping travels out and back, so to find the distance of the
  // object we take half of the distance travelled.
  return microseconds / 29 / 2;
AWOL
Any variable declared within a function like "loop" is going to have limited use for remembering its value.
If you want a variable to maintain its value, declare it with global scope.
matt121187
UKHeliBob
retrolefty
I thought declaring a variable static solves any 'memory' problem for variables declared within the scope of a function?
Lefty
UKHeliBob
These variables aren't declared static in the routine though
AWOL
It does - I just suggested global scope because it is what most noobs are more comfortable with.
