Author Topic: Problem with ModBus 485 SimpleModbus Lib. V1.4 (SOLVED)  (Read 576 times)
Oviedo
In summary, I can not get to work writing the slaves.
Reading, OK .. The Master, which received slaves shipped, (Function READ_HOLDING_REGISTERS) without problems... ; but in the other direction, no .. , Communication writing to slaves, always fails .. (function: 0x16 PRESET_MULTIPLE_REGISTERS)
IDE 1.0.2 y 1.0.3
Mega 2560
Modulo 485 de Sparfun
http://code.google.com/p/simple-modbus/
http://code.google.com/p/simple-modbus/downloads/list
MAESTRO
#include <SimpleModbusMaster1.h>
// led to indicate that a communication error is present
#define connection_error_led 13
//////////////////// Port information ///////////////////
#define baud 57600
#define timeout 1000
#define polling 200 // the scan rate
#define retry_count 3
// used to toggle the receive/transmit pin on the driver
#define TxEnablePin 23
enum
  PACKET1,
  PACKET2,
  // leave this last entry
  TOTAL_NO_OF_PACKETS
// Create an array of Packets for modbus_update()
Packet packets[TOTAL_NO_OF_PACKETS];
// The data from the PLC will be stored
// in the regs array
unsigned int regs[9];
  Serial.begin (115200);
  // read 3 registers starting at address 0
  packets[PACKET1].id = 2;
  packets[PACKET1].function = READ_HOLDING_REGISTERS;
  packets[PACKET1].address = 0;
  packets[PACKET1].no_of_registers = 3;
  packets[PACKET1].register_array = regs;
  // write the 2 registers to the PLC starting at address 3
  packets[PACKET2].id = 2;
  packets[PACKET2].function = PRESET_MULTIPLE_REGISTERS;
  packets[PACKET2].address = 3;
  packets[PACKET2].no_of_registers = 6;
  packets[PACKET2].register_array = regs;
  // P.S. the register_array entries above can be different arrays
  // Initialize communication settings etc...
  modbus_configure(baud, timeout, polling, retry_count, TxEnablePin, packets, TOTAL_NO_OF_PACKETS);
  pinMode(connection_error_led, OUTPUT);
  unsigned int connection_status = modbus_update(packets);
  if (connection_status != TOTAL_NO_OF_PACKETS)
    digitalWrite(connection_error_led, HIGH);
    // You could re-enable the connection by:
    packets[connection_status].connection = true;
    delay (50);
    digitalWrite(connection_error_led, LOW);
  // LO QUE LLEGA
  Serial.print (regs[0]);  Serial.print (" ");
  Serial.print (regs[1]);  Serial.print (" ");
  Serial.print (regs[2]);
  Serial.print (" - ");
  Serial.print (packets[PACKET1].requests);  Serial.print (" ");
  Serial.print (packets[PACKET1].successful_requests);  Serial.print (" ");
  Serial.print (packets[PACKET1].incorrect_id_returned);  Serial.print (" ");
  Serial.print (packets[PACKET1].incorrect_function_returned);  Serial.print (" ");
  Serial.print (packets[PACKET1].incorrect_bytes_returned);  Serial.print (" ");
  Serial.print (packets[PACKET1].checksum_failed);  Serial.print (" ");
  Serial.print (packets[PACKET1].buffer_errors);  Serial.print (" ");
  Serial.print (packets[PACKET1].illegal_function);  Serial.print (" ");
  Serial.print (packets[PACKET1].illegal_data_address);  Serial.print (" ");
  Serial.print (packets[PACKET1].illegal_data_value);  Serial.print (" ");
  Serial.print (packets[PACKET1].misc_exceptions);  Serial.print (" ");
  Serial.print (packets[PACKET1].total_errors);
  Serial.print (" // ");
  // LO QUE ENVIO AL EXCLAVO
  regs[3] = 30;
  regs[4] = 40;
  regs[5] = 50;
  regs[6] = 60;
  regs[7] = 70;
  regs[8] = 80;
  Serial.print (regs[3]);  Serial.print (" ");
  Serial.print (regs[4]);  Serial.print (" ");
  Serial.print (regs[5]);  Serial.print (" ");
  Serial.print (regs[6]);  Serial.print (" ");
  Serial.print (regs[7]);  Serial.print (" ");
  Serial.print (regs[8]);
  Serial.print (packets[PACKET2].requests);  Serial.print (" ");
  Serial.print (packets[PACKET2].successful_requests);  Serial.print (" ");
  Serial.print (packets[PACKET2].incorrect_id_returned);  Serial.print (" ");
  Serial.print (packets[PACKET2].incorrect_function_returned);  Serial.print (" ");
  Serial.print (packets[PACKET2].incorrect_bytes_returned);  Serial.print (" ");
  Serial.print (packets[PACKET2].checksum_failed);  Serial.print (" ");
  Serial.print (packets[PACKET2].buffer_errors);  Serial.print (" ");
  Serial.print (packets[PACKET2].illegal_function);  Serial.print (" ");
  Serial.print (packets[PACKET2].illegal_data_address);  Serial.print (" ");
  Serial.print (packets[PACKET2].illegal_data_value);  Serial.print (" ");
  Serial.print (packets[PACKET2].misc_exceptions);  Serial.print (" ");
  Serial.print (packets[PACKET2].total_errors);  Serial.println (" ");
  delay (100);
ESCLAVO
#include <SimpleModbusSlave1.h>
//////////////// registers of your slave ///////////////////
enum
  // just add or remove registers and your good to go...
  // The first register starts at address 0
  OUT1,
  OUT2,
  OUT3,
  REC1,
  REC2,
  REC3,
  REC4,
  REC5,
  REC6,
  TOTAL_ERRORS,
  // leave this one
  TOTAL_REGS_SIZE
  // total number of registers for function 3 and 16 share the same register array
unsigned int holdingRegs[TOTAL_REGS_SIZE]; // function 3 and 16 register array
  /* parameters(long baudrate,
                unsigned char ID,
                unsigned char transmit enable pin,
                unsigned int holding registers size)
     The transmit enable pin is used in half duplex communication to activate a MAX485 or similar
     to deactivate this mode use any value < 2 because 0 & 1 is reserved for Rx & Tx
  modbus_configure(57600, 2, 23, TOTAL_REGS_SIZE);
  holdingRegs[TOTAL_ERRORS] = modbus_update(holdingRegs);
  for (byte i = 0; i < 3; i++)
    holdingRegs[i] = analogRead(i+8);
    delayMicroseconds(500);
  // LO QUE ENVIA EL EXCLAVO
  Serial.print (holdingRegs[OUT1]);  Serial.print (" ");
  Serial.print (holdingRegs[OUT2]);  Serial.print (" ");
  Serial.print (holdingRegs[OUT3]);
  // RECIBE EL EXCLAVO
  Serial.print (holdingRegs[REC1]);  Serial.print (" ");
  Serial.print (holdingRegs[REC2]);  Serial.print (" ");
  Serial.print (holdingRegs[REC3]);  Serial.print (" ");
  Serial.print (holdingRegs[REC4]);  Serial.print (" ");
  Serial.print (holdingRegs[REC5]);  Serial.print (" ");
  Serial.print (holdingRegs[REC6]);
  Serial.println (holdingRegs[TOTAL_ERRORS]);
  delay (100);
The lib in the sketch, are edited to work with the serial 1
Any suggestions of what could be the mistake I'm making?
thank you very much
Greetings
« Last Edit: January 04, 2013, 07:08:53 pm by cueli » Logged
Oviedo
I answer myself ...
When the bus is free, at times it does not transmit anyone can produce erroneous readings due to noise in the pair
To avoid this, it puts a pull-up resistance in the A and a pull-down, in the B, thus, a potential is fixed to the case that all release the bus.
Interestingly, only affected the transmission, that appeared a "1" ghost, which falsified the total data received ..
http://en.wikipedia.org/wiki/File:Rs485-bias-termination.svg
http://en.wikipedia.org/wiki/RS-485
http://www.maximintegrated.com/app-notes/index.mvp/id/763
regards
