Topic: Would I use analogRead to incorporate a joystick? (Read 782 times) previous topic - next topic
tonyrogers10195
I know it sounds like a stupid question but I'm new.
I'm trying to use a N64 controllers joystick to trigger a dc motor.
I'm not exactly sure where to begin and if someone could give me a little example or point me in the right direction I would really appreciate it.
cyclegadget
Take a look at this link and if you need more help let us know.
http://www.instructables.com/id/USB-NES-controller-with-an-arduino/
Good links: Eagle tutorial= http://www.youtube.com/playlist?list=PLDE1858BD83D19C70
General Arduion tutorials = http://tronixstuff.wordpress.com
http://www.gammon.com.au/forum/bbshowpost.php?bbtopic_id=123
JimboZA
I can't speak for that model specifically, but joysticks like this one are just two potentiometers at right angles. So each axis can indeed be read through an analog pin with code like this.
HTH?
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
tonyrogers10195
That is what figured because there are 2 sets of wires coming from it.
What does HTH mean?
holmes4
AnalogRead() is good for the joystick its self. But for any buttons you will need digitalRead().
Mark
JimboZA
tonyrogers10195
OK, so I looked up the Nintendo 64 controllers->http://en.wikipedia.org/wiki/Nintendo_64_controller and according to wikipedia, they dont use a normal potentiometer. They use a light and light sensor to get the position of the switch.
I took apart an old controller, took out the joystick and the "potentiometer" controlling it, and wired to a dc motor. When its all the way down, no power. And as you twist it hits a hot spot in the middle then goes to about half power when all the way up (If that makes sense).
Also i checked out using the NES controller, is the any tutorial for a 64 controller?
