Loading...
Pages: [1] 2   Go Down
Author Topic: Generating 40kHz square wave  (Read 931 times)
Offline Offline
Newbie
View Profile
Hi, new here and probably being a bit dim but I've Googled and done all the obvious stuff and I cannot figure out how to program the PWM to get a 40kHz signal to drive an ultrasonic sender for a distance measurement device.
I've got the example below running an giving me 8kHz but how do I scale this to get 40kHz. Also on my ATMega1280 the output is on pin 13, not pin 6 which this example code suggests (I guess the code is for a different processor). I've read the datasheet but it just went in and fell straight out again. Any help appreciated.
Code:
#include <avr/io.h>
int main(void)
    DDRD |= (1 << DDD6);
    // PD6 is now an output
    OCR0A = 128;
    // set PWM for 50% duty cycle
    TCCR0A |= (1 << COM0A1);
    // set none-inverting mode
    TCCR0A |= (1 << WGM01) | (1 << WGM00);
    // set fast PWM Mode
    TCCR0B |= (1 << CS01);
    // set prescaler to 8 and starts PWM
    while (1);
        // we have a working Fast PWM
Logged
Offline Offline
Edison Member
View Profile
You need a pwm mode that allows you to set the top.
Logged
Global Moderator
UK
Online Online
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Quote
Was the any more to your post, dhenry?
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
UK
Offline Offline
Tesla Member
View Profile
You need to carefully read Nick Gammon's web site, I'd suggest starting here:
Nick Gammon's description of Timers and Counters
Logged
Pittsburgh, PA, USA
Offline Offline
Faraday Member
I only know some basic electricity....
View Profile
PWM frequency on the Playground:
http://playground.arduino.cc//Code/PwmFrequency
Quote
Please keep in mind that changing the PWM frequency changes the Atmega's timers and disrupts the normal operation of many functions that rely on time (delay(), millis(), Servo library).
Logged
Examples can be found at Learning in the Main Site and at the Playground
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Which mode is that?
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
One of my sketches on the page below generates 50 KHz:
http://www.gammon.com.au/forum/?id=11504&reply=6#reply6
By changing this line you should be able to get 40 KHz:
Code:
const long frequency = 50000L;  // Hz
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Yep, it does, looks pretty accurate too:
Sketch:
Code:
const byte LED = 3;  // Timer 2 "B" output: OC2B
const long frequency = 40000L;  // Hz
  pinMode (LED, OUTPUT);
  TCCR2A = _BV (WGM20) | _BV (WGM21) | _BV (COM2B1); // fast PWM, clear OC2B on compare
  TCCR2B = _BV (WGM22) | _BV (CS21);         // fast PWM, prescaler of 8
  OCR2A =  ((F_CPU / 8) / frequency) - 1;    // zero relative
  OCR2B = ((OCR2A + 1) / 2) - 1;             // 50% duty cycle
  }  // end of setup
void loop() { }
Logged
Offline Offline
Newbie
View Profile
Thanks for the replies, I'll give that a go
Logged
Offline Offline
Newbie
View Profile
Sorry to resurrect an old(ish) thread but what is the best way to stop and start this timer? I am using it for ultrasonic distance measurement so I need to send out a short ping and then listen for the echo. The ping needs to be short - is it best to just set the pin to input from output or do I need to stop the PWM, if so how?
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Turning the pin to input is probably the simple way to stop it.
The thing that actually starts the timer is the CS21 part of this line (the clock source):
Code:
So the above line starts it. This would stop it:
Code:
  TCCR2B = _BV (WGM22) ;         // fast PWM, timer off
Logged
Pittsburgh, PA, USA
Offline Offline
Faraday Member
View Profile
The full doc gives all the registers and commands, 55 pages of answers for those who ain'ts gots:
http://www.atmel.com/search.aspx?q=+ATMEGA328P&as_q=inmeta%3Aasset_type~Datasheets%2Binmeta%3Aproduct_family%3DAtmel%2520AVR%25208%252D%2520and%252032%252Dbit&dnavs=inmeta%3Aasset_type~Datasheets%2Binmeta%3Aproduct_family%3DAtmel%2520AVR%25208%252D%2520and%252032%252Dbit&filter=0&btnG=Search&client=support_frontend&proxystylesheet=support_frontend&output=xml_no_dtd&getfields=*&oe=UTF-8&ie=UTF-8&ud=1&num=1000&sort=date%3AD%3AL%3Ad1&lr=lang_en&exclude_apps=1&site=en_collection
BTW that's in thanks to your code in reply #7 Nick.
« Last Edit: February 01, 2013, 04:31:12 pm by GoForSmoke » Logged
Offline Offline
Newbie
View Profile
Logged
Offline Offline
Newbie
View Profile
Apologies for reviving this thread again, but I am now trying to use a similar bit of code to generate a 1kHz signal, however it is fine down to about 8kHz but it won't go below that. I suspect that it is due to the fast PWM but I have read the datasheet and I haven't got a clue how to stop using the Fast PWM.
Any help greatly appreciated.
Logged
Pittsburgh, PA, USA
Offline Offline
Faraday Member
View Profile
Why use PWM at all? Just set up a timer and interrupt to change the pin state.
Logged
Pages: [1] 2   Go Up
Print
Jump to:
