« on: December 30, 2012, 03:18:25 pm » |
Hi, new here and probably being a bit dim but I've Googled and done all the obvious stuff and I cannot figure out how to program the PWM to get a 40kHz signal to drive an ultrasonic sender for a distance measurement device. I've got the example below running an giving me 8kHz but how do I scale this to get 40kHz. Also on my ATMega1280 the output is on pin 13, not pin 6 which this example code suggests (I guess the code is for a different processor). I've read the datasheet but it just went in and fell straight out again. Any help appreciated. #include <avr/io.h>
int main(void) { DDRD |= (1 << DDD6); // PD6 is now an output
OCR0A = 128; // set PWM for 50% duty cycle
TCCR0A |= (1 << COM0A1); // set none-inverting mode
TCCR0A |= (1 << WGM01) | (1 << WGM00); // set fast PWM Mode
TCCR0B |= (1 << CS01); // set prescaler to 8 and starts PWM
while (1); { // we have a working Fast PWM } }
« Reply #1 on: December 30, 2012, 03:27:06 pm » |
You need a pwm mode that allows you to set the top.
UK
« Reply #2 on: December 30, 2012, 03:31:42 pm » |
You need a pwm mode that allows you to set the top. Was the any more to your post, dhenry?
Pittsburgh, PA, USA
I only know some basic electricity....
« Reply #4 on: December 30, 2012, 08:13:26 pm » |
PWM frequency on the Playground: http://playground.arduino.cc//Code/PwmFrequencyPlease keep in mind that changing the PWM frequency changes the Atmega's timers and disrupts the normal operation of many functions that rely on time (delay(), millis(), Servo library).
Examples can be found at Learning in the Main Site and at the Playground
Melbourne, Australia
Online
Shannon Member
Lua rocks!
« Reply #5 on: December 31, 2012, 12:50:14 am » |
Which mode is that?
Online
Shannon Member
Lua rocks!
« Reply #6 on: December 31, 2012, 12:51:57 am » |
One of my sketches on the page below generates 50 KHz: http://www.gammon.com.au/forum/?id=11504&reply=6#reply6By changing this line you should be able to get 40 KHz: const long frequency = 50000L; // Hz
Online
Shannon Member
Lua rocks!
« Reply #7 on: December 31, 2012, 12:56:21 am » |
Yep, it does, looks pretty accurate too:  Sketch: const byte LED = 3; // Timer 2 "B" output: OC2B
const long frequency = 40000L; // Hz
void setup() { pinMode (LED, OUTPUT);
TCCR2A = _BV (WGM20) | _BV (WGM21) | _BV (COM2B1); // fast PWM, clear OC2B on compare TCCR2B = _BV (WGM22) | _BV (CS21); // fast PWM, prescaler of 8 OCR2A = ((F_CPU / 8) / frequency) - 1; // zero relative OCR2B = ((OCR2A + 1) / 2) - 1; // 50% duty cycle } // end of setup
void loop() { }
« Reply #8 on: December 31, 2012, 05:05:11 am » |
Thanks for the replies, I'll give that a go
« Reply #9 on: February 01, 2013, 03:50:42 pm » |
Sorry to resurrect an old(ish) thread but what is the best way to stop and start this timer? I am using it for ultrasonic distance measurement so I need to send out a short ping and then listen for the echo. The ping needs to be short - is it best to just set the pin to input from output or do I need to stop the PWM, if so how?
Online
Shannon Member
Lua rocks!
« Reply #10 on: February 01, 2013, 03:56:16 pm » |
Turning the pin to input is probably the simple way to stop it. The thing that actually starts the timer is the CS21 part of this line (the clock source): TCCR2B = _BV (WGM22) | _BV (CS21); // fast PWM, prescaler of 8
So the above line starts it. This would stop it: TCCR2B = _BV (WGM22) ; // fast PWM, timer off
Pittsburgh, PA, USA
« Reply #11 on: February 01, 2013, 04:29:40 pm » |
« Last Edit: February 01, 2013, 04:31:12 pm by GoForSmoke »
« Reply #12 on: February 02, 2013, 02:39:50 pm » |
« Reply #13 on: March 26, 2013, 04:32:19 pm » |
Apologies for reviving this thread again, but I am now trying to use a similar bit of code to generate a 1kHz signal, however it is fine down to about 8kHz but it won't go below that. I suspect that it is due to the fast PWM but I have read the datasheet and I haven't got a clue how to stop using the Fast PWM.
Any help greatly appreciated.
Pittsburgh, PA, USA
« Reply #14 on: March 26, 2013, 04:40:27 pm » |
Why use PWM at all? Just set up a timer and interrupt to change the pin state.
