Topic: Generating 40kHz square wave (Read 12845 times) previous topic - next topic
sirch
Hi, new here and probably being a bit dim but I've Googled and done all the obvious stuff and I cannot figure out how to program the PWM to get a 40kHz signal to drive an ultrasonic sender for a distance measurement device.
I've got the example below running an giving me 8kHz but how do I scale this to get 40kHz. Also on my ATMega1280 the output is on pin 13, not pin 6 which this example code suggests (I guess the code is for a different processor). I've read the datasheet but it just went in and fell straight out again. Any help appreciated.
#include <avr/io.h>
int main(void)
    DDRD |= (1 << DDD6);
    // PD6 is now an output
    OCR0A = 128;
    // set PWM for 50% duty cycle
    TCCR0A |= (1 << COM0A1);
    // set none-inverting mode
    TCCR0A |= (1 << WGM01) | (1 << WGM00);
    // set fast PWM Mode
    TCCR0B |= (1 << CS01);
    // set prescaler to 8 and starts PWM
    while (1);
        // we have a working Fast PWM
dhenry
You need a pwm mode that allows you to set the top.
AWOL
Was the any more to your post, dhenry?
PeterH
You need to carefully read Nick Gammon's web site, I'd suggest starting here:
Nick Gammon's description of Timers and Counters
GoForSmoke
PWM frequency on the Playground:
http://playground.arduino.cc//Code/PwmFrequency
Please keep in mind that changing the PWM frequency changes the Atmega's timers and disrupts the normal operation of many functions that rely on time (delay(), millis(), Servo library).
1) http://gammon.com.au/blink  <-- tasking Arduino 1-2-3
2) http://gammon.com.au/serial <-- techniques howto
Tasking: techniques make the trees, the sketch is the woods.
See the woods and the trees, comment both.
nickgammon
Which mode is that?
nickgammon
One of my sketches on the page below generates 50 KHz:
http://www.gammon.com.au/forum/?id=11504&reply=6#reply6
By changing this line you should be able to get 40 KHz:
const long frequency = 50000L;  // Hz
nickgammon
Yep, it does, looks pretty accurate too:
Sketch:
const byte LED = 3;  // Timer 2 "B" output: OC2B
const long frequency = 40000L;  // Hz
  pinMode (LED, OUTPUT);
  TCCR2A = _BV (WGM20) | _BV (WGM21) | _BV (COM2B1); // fast PWM, clear OC2B on compare
  TCCR2B = _BV (WGM22) | _BV (CS21);         // fast PWM, prescaler of 8
  OCR2A =  ((F_CPU / 8) / frequency) - 1;    // zero relative
  OCR2B = ((OCR2A + 1) / 2) - 1;             // 50% duty cycle
  }  // end of setup
void loop() { }
sirch
Thanks for the replies, I'll give that a go
sirch
Sorry to resurrect an old(ish) thread but what is the best way to stop and start this timer? I am using it for ultrasonic distance measurement so I need to send out a short ping and then listen for the echo. The ping needs to be short - is it best to just set the pin to input from output or do I need to stop the PWM, if so how?
nickgammon
Turning the pin to input is probably the simple way to stop it.
The thing that actually starts the timer is the CS21 part of this line (the clock source):
So the above line starts it. This would stop it:
  TCCR2B = _BV (WGM22) ;         // fast PWM, timer off
GoForSmoke
sirch
sirch
Apologies for reviving this thread again, but I am now trying to use a similar bit of code to generate a 1kHz signal, however it is fine down to about 8kHz but it won't go below that. I suspect that it is due to the fast PWM but I have read the datasheet and I haven't got a clue how to stop using the Fast PWM.
Any help greatly appreciated.
GoForSmoke
Why use PWM at all? Just set up a timer and interrupt to change the pin state.
