Topic: can you read or write 8 bits at once? (Read 4520 times) previous topic - next topic
Tom Carpenter
#15
Jan 01, 2013, 09:41 pm Last Edit: Jan 01, 2013, 09:43 pm by Tom Carpenter Reason: 1
I agree, once you get used to hex there is little need for binary.
For those that don't know, here is a little tip for Binary to hex conversion:
Take a binary number (works for any number of bits, but lets choose 13 to demonstrate):
Code: [Select]
0b1101101101010
Split it into groups of four bits starting from right to left
Code: [Select]
   1   1011   0110   1010
If there arent a multiple of four bits, then pad with zeros until there are (now you see why I chose 13)
Code: [Select]
0001   1011   0110   1010
Now convert each group into decimal [base 10] (you can skip this step when you get used to it)
Code: [Select]
 1      11      6     10
Now convert each group into hex [base 16]
Code: [Select]
 1       B      6     A
Finally, stick it back together, and you have your hexadecimal number:
Code: [Select]
0x1B6A
~Tom~
