Author Topic: Interfacing an Esplora to an Xbee  (Read 1985 times)
US
Electronics are the new Legos
I connected an Xbee to my Esplora via the new expansion header.
See details on http://21stdigitalhome.blogspot.com/2012/12/arduino-esplora-interfaced-to-xbee-radio.html.
I used a small modification to the EsploraRemote example to use Serial1 (the hardware serial) rather than the USB Serial port.  Rather simple if you have the new expansion pinout documented at http://21stdigitalhome.blogspot.com/2012/12/esplora-expansion-header-pinouts.html
Hopefully this will provide you all with some ideas on making the Esplora your next wireless controller.
USA
Stick a battery on it, have it communicate with an Uno with a motor controller and you got yourself an RC car. Good job.
US
Yes, the next step in this project would be a LiPo batter backpack.  Nothing baked into the Esplora so I'll have to roll one myself.
I'm thinking the Adafruit LiPo unit http://adafruit.com/products/259 or http://adafruit.com/products/280 but they probably will not output 5 volts.
Also, which connection to use to output the juice - I was thinking of hijacking one of the TinkerKit connectors to push in 5 volts.
Anyone have good thoughts?
USA
I was thinking of trying this http://www.liquidware.com/shop/show/MBP/Lithium+Backpack
US
I couldn't wait to make it fully wireless, so I strapped on a cell phone emergency battery.  I also updated the code to output ASCII characters when the buttons are pressed and joystick moved (similar to example EsploraKart but to the XBee radio rather than to the Esplora Keyboard interface).
Details, Youtube vid, code at http://21stdigitalhome.blogspot.com/2013/01/arduino-esplora-as-fully-wireless.html
Maine
This is a very intriguing idea. I wonder if it might be possible to connect the Seeed Studio XBee Shield (http://www.seeedstudio.com/depot/xbee%C2%AE-shield-p-419.html), through the ISCP headers instead of the TFT expansion headers?  If at all possible, this would be a major bonus as this shield, like the Esplora itself, is widely distributed (in the U.S at least) at Radio Shack retail outlets.
 The shield has a small footprint and is meant to attach to a standard controller with a full ISCP Header and a single row header but fits nicely on the Esplora using only the ISCP- (See Attached Photo-https://picasaweb.google.com/lh/photo/sB5WVVc86AXqcR_F13Qwz9MTjNZETYmyPJy0liipFm0?feat=directlink
 The only major downside is the same problem that affects any product produced by Seeed Studio...  The extreme lack of documentation!  The product wiki page- http://www.seeedstudio.com/wiki/index.php?title=XBee%C2%AE_Shield still officially applies to version 1.1 even though the current version is 1.2, and while differences between them appear to be minimal, the documentation is confusing in any case...
  I've never used the ISCP headers, or SPI Communications at all for that matter before, and from what I've been able to gather, the Leonardo has an altogether different pinout of these headers anyway.
  So is this a possibility?  It would make your suggestion significantly easier to deploy for a great many people!
US
The ICSP uses SPI (MISO, MOSI, SCK) and these are also connected to the Esplora 10 pin expansion header.  XBees and similar radios communicate over TTL serial (RX, TX).  You are right that the Seeed documentation is rather poor.
I did use the SoftwareSerial library to connect to the XBee (in addition to the Serial1 hardware connection) and it works as expected.  So one could repurpose two of the pins in the ICSP header to do TTL serial communications, yes.  The Seeed code uses pins 11 and 12 and NewSoftSerial and that should work... But you most likely could not also do display on the new expansion header as this uses these SPI pins in their intended configuration.
A better option could be to use D3 and D11 exposed on the two orange TinkerKit connectors with SoftSerial.  These would not interfere with the display or SPI functionality.  There is not a pre-made board for this though.
Keep up working on possibilities.
« Last Edit: January 01, 2013, 09:51:09 pm by TheKitty » Logged
US
I used the Esplora/XBee/Battery controller today to send the joystick and button commands to another XBee on an Uno with an Adafruit motor shield to move a robotic head.
Details at http://21stdigitalhome.blogspot.com/2013/01/wireless-arduino-esplora-controls.html
