« on: December 31, 2012, 05:12:41 pm » |
I've created a board that has 2-pin, 3-pin and 4-pin 0.1" male headers that are all meant to connect to off-board components like other boards, LEDs and potentiometers. I ordered some housings from Digikey that fit my headers just fine, but I'm having a really hard time getting the crimp contacts to fit! Here is an example of the 4-pin housing that I got: http://www.digikey.com/product-detail/en/0022013047/WM2002-ND/26435And here are the crimp contacts, which are listed as an Associated Product for the housing above: http://www.digikey.com/product-detail/en/1375819-1/A100453CT-ND/2233146I am using solid core wire from an ethernet cord (24AWG I believe). I can get the contact crimped to the wire just fine, but when I try to insert it into the housing there is significant resistance. Even when I take pliers and push hard, all that happens is the crimp contact snaps in half! Is there another tool I need to make this work? Maybe the crimp contacts are not good for my housings (even though they are an Associated Product on Digikey)? Does anyone have some info about how to assemble my own cables like this? Or is there maybe a better interconnect solution that I don't know about to get off-board components wired up?
« Last Edit: December 31, 2012, 05:35:50 pm by h4t »
Grand Blanc, MI, USA
"We're a proud service of the Lost Electricity Reclamation Agency"
« Reply #1 on: December 31, 2012, 05:44:57 pm » |
I may be missing it in the associated product list. The first thing that caught my eye is that the housing and pins you linked are from different manufacturers, which doesn't mean they don't work together, but...
FWIW, I find connectors a huge pain. Very difficult to find just what I want, mating parts, etc., especially when places like Digi-Key or Mouser list about a million part numbers. Real needle in the haystack.
Massachusetts, USA
« Reply #2 on: December 31, 2012, 06:38:47 pm » |
Looks like your housing is Molex series "KK® 2759" and the pins are TE Connectivity series "CST-100 II". Probably best to stick with one manufacturer and series.
Boston area, metrowest
Online
« Reply #3 on: December 31, 2012, 06:44:02 pm » |
I find the crimp terminals, crimp terminated wires, and crimp housings from pololu.com all work well together.
For ribbon cable/IDC, I've been getting parts from phoenixent.com. Lot easier to find stuff vs buried at digikey/mouser. Getting ready to make up 28 cables to connect a breakout board to 28 dual-7-segment display boards.
digikey does have a good selection of JST connectors, I've designed the 1.5mm, 2.5mm, and 3.5mm pitch connectors, both thru hole & surface mount, into several boards (2,3,4,5,6,8 pin variants). Someone else ordered the mating JST female header with wires, we crimped pololu pins onto the flying leads and put them into crimp housings to mate with AVR ISP programmers, USB/Serial boards, and other boards.
« Reply #4 on: December 31, 2012, 07:04:54 pm » |
Great responses, thanks. It looks like the 2 and 4 pin housings I ordered were from the KK series, while the 3-pin housings were from the CST series. When I went to order the crimp contacts, I grabbed contacts that were associated with the CST series, not the KK series. I've decided to go with bare male headers so that the housings don't need to be polarized or have anything fancy on them (locking ramps, friction lock, etc.). I found housings such as the following in the KK 2695 series: http://www.digikey.com/product-detail/en/22-01-2031/WM1576-ND/1090454The following crimp pins are in the Associated Products list: http://www.digikey.com/product-detail/en/0008500113/WM1114CT-ND/467980But the crimp pins are in series KK 2759 series. I have a hunch that the numbers are less indicative than the letters (KK), but does anyone know for sure what that naming scheme is about?
« Reply #5 on: January 05, 2013, 09:52:08 pm » |
Update: making custom cables sucks!
The crimp contacts and housings appear like they would mate, but every time I crimp a wire on and try it insert it, more often than not the wire snaps off. The specs for the contacts say they work with 20-26AWG, but my 22AWG hookup wire doesn't seem to fit. Thin solid wire taken from ethernet cables (I think 24-26AWG) bends very easily and snaps.
This process appears really straightforward, but is turning out to be the most frustrating part of assembling my project! Am I doing something wrong, or is custom cable assembly best left to machines and factories?
« Reply #7 on: January 06, 2013, 08:04:27 pm » |
Thin solid wire taken from ethernet cables (I think 24-26AWG) bends very easily and snaps. No no no no. You need braided wires.  What tool are you using to crimp?
Anchorage, AK
« Reply #8 on: January 08, 2013, 05:19:22 pm » |
I use Molex connectors on a lot of my projects. Sometimes I don't know if they're worth the effort. They're expensive, a pain in the butt to work with, finding the right pins can be a hassle, and twice now I've ordered a bunch of stock parts that later become discontinued before I've used up the mating ends. UGH.
Definitely use stranded wire. The mechanical grip on those tiny pins just won't work well with solid core. Since the pins usually have "flaps" that fold over from the sides, I usually use pliers to get them started, so they're bent over the wire. Then I use one of those Radio Shack crimping tools with the nub on one handle and the slightly larger recess on the other side. This pushes the two flap ends into the wire. Not as nice as the photo in the previous post, but they seem sound enough.
I'd love to have one of the nice specialty crimpers to produce a nice bind like that picture, but the price of the official tools is downright ridiculous. If I ponied up $200 or more for a crimper and then had to abandon my stock when Molex decides to stop producing that part, I'd rage-quit electronics. If in doubt, just add a touch of solder.
« Reply #9 on: January 08, 2013, 06:59:21 pm » |
I'd love to have one of the nice specialty crimpers to produce a nice bind like that picture, but the price of the official tools is downright ridiculous. If I ponied up $200 or more for a crimper and then had to abandon my stock when Molex decides to stop producing that part, I'd rage-quit electronics. If in doubt, just add a touch of solder. I don't have the correct crimper either, and I usually end-up soldering.
Online
« Reply #10 on: January 08, 2013, 10:05:29 pm » |
Centennial, CO
It should work...
« Reply #12 on: January 09, 2013, 03:21:35 am » |
I go to Newark for my pin headers (Multicomp) as they are dirt cheap. I also get the crimp pins from there too. I had been using needle nose pliers and soldering. I just got an Engineer PA-09 crimper that does a fantastic job (even on sold core which I know is non-ideal). This is like (if not exactly) the connector I usually get in bulk: http://www.newark.com/harwin/m20-1180046/connector-contact-female-22awg/dp/96K4323. I ordered a batch of housings a while ago and don't remember the brand by you might look at Harwin or anyway the same manufacturer as the crimp connectors.
Online
« Reply #13 on: January 09, 2013, 07:25:44 pm » |
