Topic: External Memory Interface library for the Mega. (can someone review my code?) (Read 2217 times) previous topic - next topic
DigitalJohnson
  I've just finished a library to use the External Memory Interface module on the Mega1280/2560. You can use it to access external memory via parallel address/data bus. The address bus width is from 8-bits upto 16-bits and the data bus width is 8-bits. You'll need a 74AHC573 transparent latch to multiplex the Port A address/data lines. I've tested the library with ti's bq3287EA RTC and an Atmel AT28HC256 EEPROM both connected. I could access the RTC as the lower sector and the EEPROM as the upper sector. The library has four functions; enable(), disable(), read() write(). The library can read/write to any valid data type (including string literals) to any external memory address. The lirary zip file is on google code here: http://code.google.com/p/arduino-exmem-library/downloads/list and attached below. If anyone can review my code or better yet test it out and let me know what they think, I would apreciate it. Enjoy! ;)
Thanks for your time,
DigitalJohnson
DigitalJohnson
westfw
Um.  Why?  I thought the whole point of the "external memory interface" (as opposed to using random IO ports to access a memory device) is that the memory appears in the AVR address space, and can be accessed via normal C code.  There's a good summary accompanying the Rugged RAM expansion module: http://ruggedcircuits.com/html/megaram.html
And notes in avr-libc on how to set things up so that malloc() and friends will use it:  http://www.nongnu.org/avr-libc/user-manual/FAQ.html#faq_ext_ram
I guess your code handles the bank boundary "invisibly."  But at great computational cost...
slomobile
Thank you for the library.  It is very nearly what I need to access some non memory devices only available with multiplexed address/data busses.  http://mektronixtech.com/  My application uses 4 of these chips.  Using malloc in this case would be a disaster.  I need to read from and write to specific addresses.  With partial addressing to control the CS lines of each chip, the code I am left to write is minimal.  Any reason this wouldn't work with teensy2++?  The chip is different, an AT90USB1286, but I think the register defines are the same.  Leonardo might work too.
DigitalJohnson
@slomobile
I looked at the data sheet for the AT90USB1286 and the register names are the same so it should work.
DJ
DigitalJohnson
