Topic: Using a Resitor to fix Glasses :) (Read 3695 times) previous topic - next topic
cjdelphi
Jan 01, 2013, 05:34 am Last Edit: Jan 01, 2013, 05:36 am by cjdelphi Reason: 1
After careful consideration, some of the cheaper resistors particularly the 68ohm 100+ packs cheapies have even thinner legs than i'm used to, not sure if it's a good or bad thing...
So after crushing the arm off my driving specs (by sitting on them) the tiny tiny screw vanished to never be seen again and i don't have any tiny enough, low and behold the cheap 68ohm resistors from ebay are perfect size :D
I cut one end off leaving the tip, dropped the resistor in, apply solder, fixed, small intrusive and I'm the only geek who drives wearing glasses with a resistor as a fix :D LOL sad the things i do, but anyway it works fine it acts as a pin no squeaks, seems perfectly good to use, i'll know when i use them to drive with next.
CrossRoads
Docedison
--> WA7EMS <--
"The solution of every problem is another problem." -Johann Wolfgang von Goethe
I do answer technical questions PM'd to me with whatever is in my clipboard
cjdelphi
The wife says it's "GeekSheek" I say it's a handy resistor to have in-case of emergency...
robtillaart
you should copyright this look and start a kick-starter project e.g. - nerdGlasses , jewelry etc -
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
dc42
Why not add a coin cell and LED as well, then you'll have a built-in reading light!
Formal verification of safety-critical software, software development, and electronic design and prototyping. See http://www.eschertech.com. Please do not ask for unpaid help via PM, use the forum.
arduinohabib
Nice! I'd make sure to do that next time I lose my glasses screws :-)
What is man's best friend? The breadboard!
CrossRoads
Yes, copy the look, sort of like the steampunk look ;)
JimboZA
Quote
Quote
A bit Lady Ada-ish.... Will the real Limor Fried please stand up?
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
jroorda
I've done this with a small piece of wire before.  Now every new pair of glasses gets some blue Loctite thread-locker.  No more issues since.
Jack Christensen
No doubt this is the start of a new trend. Plus, I'm sure the glasses will be more resistant to breaking in the future.
JimboZA
Quote
more resistant
BZZZZZZZZZZT.... cr@p pun  :smiley-yell:
Jack Christensen
Quote
more resistant
I know! Sorry, couldn't resist XD
JimboZA
Quote
As The Katzenjammer Kids used to say, "Gifs moider!"
MAS3
Are you sure this will work as planned ?
Could be the camera (or me) but this doesn't seem to be a 68 Ohms resistor.
Maybe you should check the value before you put the load on it.
Have a look at "blink without delay".
Did you connect the grounds ?
Je kunt hier ook in het Nederlands terecht: http://arduino.cc/forum/index.php/board,77.0.html
