Topic: Standalone Setup (Read 10530 times) previous topic - next topic
CrossRoads
Try this thread for the Jungo driver replacement. It's what worked for me with Windows Vista.
"How to configure the Atmel AVRISP MKii to work with Arduino IDE"
http://arduino.cc/forum/index.php/topic,118089.0.html
dc42
AFAIR I got my driver from libusb.org as mentioned in that thread. The stuff about editing the boards.txt file is not needed with Arduino 1.0 and later because it has the "Upload using programmer" function. I'm using Windows 7 32-bit and have no problems using the AVRISPmkII with both AVR Studio 6 and Arduino 1.02 as long as I switch drivers when going between the two. Perhaps there is an issue with the 64-bit version of the driver?
Formal verification of safety-critical software, software development, and electronic design and prototyping. See http://www.eschertech.com. Please do not ask for unpaid help via PM, use the forum.
jtw11
Ah yes - I should mention, I'm using Win7 - not Vista that people seem to have the MK II working with in the Arduino IDE.
GarageGeek
Perhaps this is the case.  No matter what driver I try, I just have no luck getting it to work via the IDE on my 64 bit machine.  Not a big deal.  It's working via AVR Studio 6 and I've enjoyed learing about fuses and lock bits anyway.  Seems like I will have lots more options for chip configurations.  I got to spend some tme in the datasheet too!  :-)
I'm really lost in AVR studio.  Seems I've got more to learn about C++ programming.
The Uno is repaired and I'm programming my sketches on standalone boards to be inserted into my projects.  I'll consider that a success.  No doubt I I've covered territory that was covered before, but it was worth it.  Thanks for all the great help.
dc42
Arduino programming is C++ programming. The main differences are:
1. In the Arduino environment, all the core functions and libraries are available by default. In AVR Studio you need to copy any Arduino core functions and libraries you need into your project.
2. In C++ you need to declare anything you reference before you refer to it (with a few exceptions, such as class member declarations referred to from other declarations in the same class). The Arduino environment generates forward declarations for you automatically, so you mostly don't need to worry about this.
The AVR Studio editor is much nicer than the Arduino editor and the error messages are shown in the right place. I generally use AVR Studio for ATtiny programming, but Arduino IDE for atmega328p and larger programming.
codlink
I had the same problem with my Win7 x64 machine.  I found these drivers to work with my setup.
http://mightyohm.com/blog/wp-content/uploads/2010/09/avrispmkii_libusb-win32_1.2.1.0.zip - direct download
http://mightyohm.com/blog/2010/09/avrisp-mkii-libusb-drivers-for-windows-7-vista-x64/ - Web page that has the download link.
I know it has 32 in the title but it works for x64.
//LiNK
